Beautiful Jim! While I'm not a Sante Fe fan either, those units are classics! Well done!
Two suggestions. First, you mention a single sound decoder. If you really want to blow your socks off, put a second sound decoder in a second unit, preferably the two A units, or an A and second B, spacing them apart. You will be shocked at just how much better it sounds with two sounds rather than just one. With the great job you did on these, they deserve it!
Second suggestion, it appears that you used standard Kadee #5 couplers, resulting in the units being spaced a little too far apart from on another. Swap them out with the short shank couplers that will result is a closer coupling. It will improve the appearance of the lash up dramatically.
Looking great Jim! Nice job!
