Thanks guys for the compliments. They are much appreciated.
One of the pet peeves has been the wiring on production locomotives. Now I understand that it needs to be less complicated and be fast to install. With this plug-n-play wiring it's easy to just unplug instead of warming up the soldering iron to unsolder the wires and then solder them back on. I'm glad that it may give others some ideas.
I added the bars to the engine do to the fact that the trailing truck could get hung up on the wires or vis-versa. I won't need to add a bar to the tender since the wires come through the holes drilled into the floor. The hole is just large enough to fit two wires through.
As far as stopping into the Bowser store in PA, a date has not been set yet. I'll let the crew know when that will happen.
The tender will get some attention next. I've got an idea for doing something with that wide open foot board. Plus I need to figure out about running an oil line hose and a water hose between the engine and tender. Progress could be a little slow from here on in.
I'm getting anxious on starting a TT scale building for my diorama I started this past winter. Also planning on a rebuild of the TT scale lumber module I had started. After seeing Joey Ricards video on the new HO scale module, I'd like to build mine the same way.
That's about it for now.
