My next project is a small block of buildings for use on a 1:29 scale diorama named "Hard Times".
Like most of my buildings they will be made from foamboard and paper with some clay added to the mix.
I started with a very rough sketch showing the approximate dimensions of buildings, placement and the footprint size of the block.
The intent is to build a two story tavern and a three story cheese retail building separated with a parking space in the area where a building was razed.
I told you it was a very rough sketch!
GUFFEY TAVERN
Early January, Bob Santos made a block of buildings with one named Guffey's Tavern and one named Magoun House of Cheese. His build gave me the bug to build a few of these businesses for "Hard Times". Thanks Bob!
The first process is the layout and cutting of the foamcore board.
I wanted the walls to be variable size stone blocks with three different thickness to provide texture and depth.
I used oven bake clay to make the stone. The textured pieces in the print below are pieces of tile used to push a texture pattern into the clay.
Roll the clay into varying thicknesses in approx. 6" x 8" sections. ( I used 1/16", 3/32" and 1/8" thicknesses)
Use the tile stones to add pattern to the entire section of clay. After adding patterns cut length wise into varying size strips. ( I used 1/4", 3/8" and 1/2")
The hash marks on the top three pieces are shallow and used as a gauge to cut the stones after the strips are fired.(bottom two rows) Fire clay in oven for 15 minutes at 365 degrees. The fired clay is easy to cut with a #11 blade.
Use Aleene's Fast Grab Tacky Glue or E6000 cement to attach stones in random patterns and thicknesses.
After stones are attached and glue is dry use DryDex Spackling to fill the mortar joints. DryDex is neat because it goes on pink so you can see what you are doing and dries white.
Now the fun part...coloring the stones.
I wanted the stones to have a Scottish look so I printed a picture of British Blue Stone for a paint guide.
The paint blotches are different colors of acrylic paints with lines drawn to the coordinating color stones in the print.
This approach keeps me from getting mixed up on which paint to use and guides me on the amount of each color to apply.
Next time we paint the stones!
