Intermittent wheel to truck sideframe short
  • Intermittent wheel to truck sideframe short
    Sometimes the manufacturer makes the axle holes too big in a truck with metal sideframes. Once the paint wears off, this produces intermittent shorts.
    When this happened to an Overland B&M caboose with conical journals, I couldn't replace the trucks; they were unique to the prototype. I measured the axle length with calipers and bought wheelsets with longer axles from Reboxx.
    But this Bethlehem Car Works Kitbits T95A has straight-sided journal holes. I've thought of making nylon washers to fit the journal ends of the axles. Or I could glue a bit of metal into the bottom of the hole in the sideframe.
    Has anyone else had this problem and fixed it? How, and did the fix work well in the long run?
    James, I've never had this problem or even had to address the problem, But I think your thoughts of gluing metal inside the hole of side frames would work. Myself I'd try doing one set using JB Weld Epoxy Steel resin and hardener, mixed and placed into the holes, once dry, try wheel sets and file/drill if any needed clean-up. Just my option and thoughts going on here.
      You could buy the bearings sold by Tichy. They are very nice nylon inserts and may work for you?
      https://www.tichytraingroup.com/Shop...9/Default.aspx
      Regards. Vic B.
        These look like good ideas to me. I might start with the Tichy; if the holes are too deep, try pulling the Tichy and fill with J-B, then insert the Tichy and try again.
        James, please let us know how things work out!
          Regards. Vic B.
          After seeing these bearings, I believe that is a great bit of info to know. Thanks Vic, I'll have to remember these. I have a Locomotive Maintenance and rebuild folder and will have to place this information into it. :up:
            The Tichy bearings will work, if they fit into the holes on the side frame (what are the odds that this would work out)? If they fit, that's great, otherwise I think I would be tempted to do what desertdrover suggests and filling the holes with epoxy. I think you could take an old set of plastic wheels and goober up the pointed axle ends with Vaseline (as a mold release) and put the wheel set into the uncured epoxy to mold the bearing surfaces, then use a truck truing tool to make perfect bearing pockets once the epoxy has cured. If this were me, I also wouldn't think twice about replacing the trucks with plastic ones, even though it sounds like these metal trucks are different.
