Modules
  • Modules
    I envisage the construction of modules for of 20.3 and 7/8, I arise two questions:
    - In what material made you your backdrop?
    - How fix them you to modules? Especially for an assembly and a fast dismantling for exhibitions
    Thank you of your help
    a few ideas [:-idea] to think about
    http://www.modvid.com.au/html/body_s...tral_2007.html
    " Stay Motivated in Life "
      Just visit my thread. It covers everything you may need. It starts at the beginning. Over 4 years.of stuff. Its holding up well and still adding stuff.. Ty
      http://www.railroad-line.com/forum/t...TOPIC_ID=36635
        Hello and thanks to you
        Hey Ty, I had looked well at your thread repeatedly, but as I use a translator, I had not seized everything.
        Moreover a thing which I does not include, they are your connectors: you screw in the foam with screws? It holds for several times?
        Thank you for being willing to light me
        JGD
          JGD,
          I hold the modules together with C-clamps. The end of each module does have 1/2" holes drilled and dowels are inserted for alignment. The only modules that are screwed together are the trestle modules. And I use blind nuts for those...
            Ok Ty, but I had to badly express myself.
            I wanted to speak small connectors to hold your on-line backdrops and abutting
              If you go to page 17 and 18 of my thread you can see how I did it. At first I was using screws to hold the back drop on but I have now switched to about a 2" clamp. The clamp allows me to easily adjust the back drop. The screws were a little more difficult. The small pieces of light plywood I use on the top and middle of the backdrop have held up pretty well.
              Ty
                To be made of this foam my backdrop has held up really well. You just need to store it well. I made 2 boxes that is fits into. It could easily be damaged. But i have not hand any accidents with it yet...
                Ty
                  Thank you Ty and bravo for your work
