James, Check these out... http://www.ebay.com/itm/50-x-Double-...oAAOSwd0BVta3Z
I used the above into an 8 pin DIP IC socket and they worked like a champ. I used copper tubing for the mast pipe, soldered to one of the pins as an anchor. Notice the left front leg is missing. I cut that one as the 'key'. On the topside, I bent that pin toward the center as the anchor point. After getting the four #30 wires through the mast pipe and soldering to the pins, I dabbed the upper base with JB Weld.
I need to add a ladder, and a nameplate, and it's ready to plug in to the socket. That's an NJ triple target.
