Big Power on the Coalfield Western
  • #16
    Today got the frame assembled and all squared up...Its not mounted to the truck part yet, there still some finish work and detailing bits to do, here it sits under the firebox.....
    Download Attachment: reartruck05.JPG
    50.25 KB
    • #17
      Cool!
      • #18
        This is going to be an interesting one to follow along. keep it up
        Owen Pass Lumber Company
        HO Logging Layout in a Shed.
        • #19
          So the new gearboxes came from NWSL this week....and to install them require me to remove on driver and gear from the axles, never having done this before, I don;t have a gear puller......so I looked online $25 isn;t bad for a useful tool.....but I wanna get started THIS WEEKEND......So with a Bolt, and some schedule 40 and a benchgrinder and a little ingenuity...
          Download Attachment: gearpuller.JPG
          82.67 KB
          • #20
            Clever!
            • #21
              Crews have reported to the Coalfield Western Shops on this rainy chilly Saturday.....nuttin better to do than lets build a locomotive!
              • #22
                Neat puller.
                • #23
                  Innovation rules in On30!
                  • #24
                    I like the way this is going. Keep up the good work!
                    • #25
                      I have been doing a little work, the gearboxes are installed front and rear, just need to finish putting the front engine back together, there is also a trailing truck under construction. The motor arrived yesterday too, so just as soon as I get some time, I can start putting the driveline together!!!
                      Download Attachment: 266406.jpg
                      71.46 KB
                      • #26
                        Good so-far!!!
                        Joe Batson MMR#475
                        http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=37549
                        • #27
                          Got the front engine mostly put together and the gearbox installed....s.till a minor bind to track down, but I think it might be a quartering issue. Check out the driveline geometry though, I think need an intermediate shaft, cutting the rear shaft about halfway back and then connecting to the driveline of the front engine....whatchall think?
                          Download Attachment: 266407.jpg
                          76.61 KB
                          • #28
                            Looks good, but how does it run?
                            It's only make-believe
                            • #29
                              Bart, enjoying the build. Adding an intermediate shaft would probably help vertical flexibility, but might not be needed if your running on the flat.
                              Cheers, Heath.
                              • #30
                                I got sopme photos from a feller on Faceboox who haas done the repower on the Bowser Challnger (Which is basically what this is at this point) He showed me how to get soem more angle on that front gearbox so it all lines up nicely now.....Film at 11
