I've said so elsewhere, but I need to add it here, too. I apple-laud (sorry, but I feel the "Ensign" Force this evening) both the results and the SBS that you posted here. I've admired this since it hit the model rail press a couple of years ago, and appreciate having a quick place to find the information when I need to come looking for it.
Thanks Philip! You're right, I forgot, the rear suspension was lowered a little with a file when the body was off the chassis. Same with the Vacation Woody in the other post. It does give a feeling of weight.
B_A_R, Thanks for taking a look. The driver's shirt was first painted with an off white, matte (not quite flat) acrylic paint. The brown lines were drawn with a Sakura Pigma Micron archival ink marker. The nib size was 0.005. These markers are available in a limited range of colors ( black, brown, red, green, blue) at A.C. Moore, Michael's and art supply stores. The black markers are good for drawing window gaskets around locomotive windows if the base finish has a little tooth to it. These markers will not fade like a Sharpie.
It took several tries to get enough lines to look acceptable, so the matte base color is important. A glossy base paint causes the marker to bead up. A flat base gets stained by the marker ink and needs to get repainted each time there is a goof.
Besides the apples themselves, the apple boxes also add a lot to this model. Here's a closer photo of the back of the truck. You can see there are two different styles of boxes there, two older boxes on the left and a new one on the right. They are based on the two prototype box styles posted here earlier.
