Bachmann GE 44 ton
  • #31
    Great looking 44 tonner Glenn. Nice work. :up:
    • #32
      Glenn, The more you run it it will quiet down, I have two done with sound for my Hoboken Shore RR, Now I used the GE Cummins sound from Soundtraxx 827014 and a mini oval speaker. Its not the correct sound but hay the RR sent them out and had new motors put in them. I willtry to some pic's posted of the install.
      • #33
        Bruce, I'd like to see the pictures of your sound installation.
        • #34
          Good looking unit Glen! I do love that paint scheme.
          By the way, since he suggested the sound, let's put SteamNut on the spot here! Glen, it's an ongoing joke around here. "Can Bruce put sound in that?" And he usually does! He managed to squeeze sound in both of his 44 tonners! And they sound great! So if your up to the challenge, we should have Bruce detail how he did it so others can give it a try. Bruce, your up!
          • #35
            Looks really good, Glen. I too, would like to see the sound installation. I have 4 of them to do, and there isn't a whole lot of room in there. Ron
            • #36
              Thanks for the bus hit there Mark, I will post something in the diesel shop in the next few days.
              • #37
                Thanks for all the compliments guys.
                I'm looking forward to seeing this little fellow with sound installed as well.
                • #38
                  Originally posted by Bernd
                  Glenn,
                  Neoprean tubing (model airplane fuel line). The smallest you can get. Probably your local hardware store might carry that size tubing. Only thing I found is the hole is sometimes not on center. When the motor runs at it's highest RPM you get some vibration.
                  Here's my scratchbuilt eddy current drive that I used 1/8"OD fuel line. You put a ball bearing in the tube so it bends easier for truck swivel.
                  Hope this helps. Questions, just ask.
                  Would a length of tubing around the O.D. of that broken part fix it?
                  • #39
                    Glenn,
                    Art asked:
                    Art,
                    Not quite understanding what you are asking about here. Are you talking about the couplings on the 44 tonner? If so that's an interesting solution. Although there might not be enough room to do that.
                    • #40
                      Wow! I just love seeing others do such professional modeling.
                      I'm picking up neat perspective on how I might tackle my build in the future. Thanx Thom...
