  • Thank you, Bob.
    • It's been a long day of making firewood, so no puns from me. But I like the model too.
      • quote:
        Thank you!
        Maybe we should check our puns at the door.
        • I submit that your model scale conveys the correct impression for the scene you are creating. A very nicely conceived detail with great color/weathering rendering the detail as an important, but not overly overt, component of the setting.
          -- KP --
          • Thank you, Kris.
            There was a lot of guesswork, of course, but I was aiming for general impression. Sounds like I may have succeeded. I appreciate your comment.
            • Going in Many Directions for a Couple of Weeks
              I gave this update a title because it sums up my model railroading activities recently.
              To provide a setting for my structures and trains I've been ballasting track and spreading dirt, grass and trees. I decided I needed to be able to turn my locomotives in Auburn, and so I installed an Atlas turntable temporarily:
              I couldn't see building one right away.
              I'm rethinking the other end of my layout, which was once Auburn, but will now represent a small town in the lumbering region of Pennsylvania . . . probably. Here's the current track configuration:
              You can see I removed a turnout that I needed elsewhere.
              I'm considering a wye for turning locomotives, similar to a couple of small towns on a Lehigh Valley branchline.
              The paper track template shows one leg of the wye. Existing track would form another leg. Much of the current track would be retained.
              • Interesting plans Mike. Wyes are certainly easier to build than turntables. IMHO wyes looks better with structures in the center.
                I look forward to seeing how you develop this.
                It's only make-believe
                • Another fun thing to watch in Mike's thread!
                  I can visualize a wye there, too! It would not only add to the visual interest, but it would be fun to use during operations.
                  Andre
                  • Track planning and re-planning, the fun of it all.
                    • Looks good to me Mike :up:
                      • This is fascinating, Mike, but you need to crank it up a notch before that new-fangled Interstate Commerce Commission that President Cleveland started up awhile back gets wind of this and the lawyers start asking why all those cars are suddenly isolated and therefore not available.
                        Very nice work, good ideas here, and eye candy to boot! :up:
                        Bravo!
                        • Looks like a good plan, Mike. It will be a bit of interesting trackwork if the new leg of the wye crosses that long straight track.
                          Or will that other track be moved?
                          • Thank you, everybody.
                            Bob, planning the what and where of structures is in preliminary stages right now and I’ll keep what you say in mind.
                            Andre, you’re right that the wye will be good for operating my layout. In fact it will become essential to operations and essential that it operates well. By the way, we met a young fellow from Arkansas at a cocktail party last night and we discussed the beauty and geology of the Ozarks.
                            Frank, I like the theory of track planning. You can do a lot of moving turnouts and bits of track around without actually committing to one plan. It becomes reality when the Dremel comes out.
                            Carl, thank you.
                            Pete, yes I do have a bunch of stranded rolling stock, don’t I? I haven’t quite decided if that turnout will be replaced. In any case, once I’ve ballasted track and scenicked the other end of my layout (Auburn) I’ll move all those cars out. The big hook will be needed for stranded rolling stock.
                            Bill, I guess the first thing I’ll have to do is truncate or remove that track. . . . Once I’ve finished my theoretical model railroading.
                            • Mike that is some fine modeling. Love the scale scene!
                              • quote:
                                Thank you, Jerry. I’m pleased you like it. I know I am biased but the more I worked on the gate, office and scale the happier I was with the whole coal shed. Sometimes it’s the small things.
