  • quote:
    Originally posted by Bernd
    And as you said it needs a bit of an update. A couple of links are dead ends, other than that it makes for very interesting reading. Inspires me to get something together for my railroad history.
    Bernd, thank you for perusing and poking around my website. I'll check links and add some photos in the coming days.
    Lately I've been altering my trackwork to accommodate future industries and to give my coal dealer more prominence. Here's a brief tour.
    Starting from the shops area . . .
    . . . we will pass the depot and freight house . . .
    . . . the coal trestle . . .
    . . . a brewery under construction and the packing house . . .
    . . . to the lumber yard:
    The brewery will probably move to make room for a different enterprise with lower roof lines. So far I have only built the malthouse portion with its distinctive towers where the sprouted barley was roasted. I will likely place it in an area backed by a higher backdrop to highlight the towers.
    • Looking good Mike. How about a close up of both your consolidations?
      Are they both re-boiler-ed?
      I like the placement of the coal dock. It will disguise and brake-up the backdrop nicely. I think the finished brewery will be an interesting industry and also serve to breakup the scenes.
      And nothing is too crowded ether. It's just looking very good.
      It's only make-believe
      • Thank you, Bob. My purpose for building the coal trestle was in part to disguise the backdrop, but originally I placed it into a corner with a long reach. I decided to move it to a place where the scene is much shallower for better access during operations.
        I’m trying to use some restraint in spacing industries for the sake of realism.
        I’ve only reboilered the one locomotive in the background. The other is stock Athearn and I still need to change the lettering. I’ll put up some photos.
        • Mike,
          That roasting house is indeed distinctive. It is the sort of structure that begs inquiry if it is not recognized. Neat.
          Galen
          • Mike, I just finished reading your web site. Very well written and intelligently put together'.. I enjoyed it. You sure have a very nice collection of scratch built structures and rolling stock'... Nice job all the way around Mike'.. [;-xmas]
            • Just catching up on this again , Michael. Very nice work as mentioned. Another facet of this hobby I need to learn. Thanks for your excellent tutorial. I will file this for future use. Thanks for sharing your work.
              • Thanks guys.
                Galen, Once I learned what these structures were, I could spot them in many old photos. Sometimes only one tower.
                Ted, I spent some time yesterday doing updates and (hopefully) eliminating dead links. I’m glad you liked it.
                Rich, I appreciate your comments. Very kind.
                • As promised, my two locomotives:
                  On the left, a stock Athearn consolidation, still needing lettering altered. Other than adding a DCC decoder I've left it alone. It runs great.
                  On the right is the MDC kit model that I showed on a previous page with a replaced boiler, but needing its lantern. I plan to install a decoder.
                  • Thanks Mike, They look good.
                    • quote:
                      You’re welcome Bob.
                      I’ve been busy making changes to my track plan, adding more switching spots, but I’m thinking of working on the reboilered locomotive next.
                      • Ever noticed how Forums members will disappear for weeks or months and then resurface, and it turns out they are actually building a layout? So many parts of that effort just aren't very exciting when documented step by step. They've been busy, but behind the scenes.
                        I've taken a break from building structures and rolling stock to work on track and wiring. I reworked the track on about 12' of my layout, planned where roads and structures will go, and now I am rewiring. I am determined that ALL sections of track will have drops to the bus under the layout and All turnouts will have powered frogs before I finish. I suspect like many of us, if things seem to be running well I don't do this until there is a problem, usually after ballasting the track.
                        All track is down and I've spent the past week or so rewiring. Now there's something that to document or to read would be bo-o-o-o-ring. So I've not posted much here.
                        I'll show one thing. For many years I used the Tortoise switch machines to throw turnouts and change polarity on the frog, but I decided a decade ago not to do so because I have some pretty tight situations; they can be awkward to install, especially over my head; they require additional wiring to a power source; and I like reaching into my layout and throwing some kind of mechanical device.
                        For many years that device has been the famous Caboose turnout throws with the integral contacts for controlling frog polarity. In recent years I've been installing mini slide switches because they seem less fragile and easier to work with. Here's an example installation:
                        After using some very small ones which did not have enough movement to fully throw a Shinohara turnout, I discovered a larger one that is almost perfect.
                        A modeling friend of mine really looks down on slide switches in this role, but the alternative doesn't look much more real, to my eye at least:
                        That's a spot where I have old and new installations. I might experiment with painting the slide switches to make them less noticeable.
                        I should have completed all trackwork in the part of my layout representing Auburn in the next day or so.
                        • Mike how do you avoid getting shorts with the two point rails soldered together?
                          • Mike, I think building the railroad is more important than building treads. I also think your throw linkage would be better if you put a "V" in the Perpendicular part of the wire to give you a little spring action on the points.
                            • You know Mike, what they say', "to each his own". The best part about a individuals layout is the freedom of doing it the way that makes you happy'.. I like those switches, and they make good sense. If they install easy and work well, hey, that's half the battle right. Also, very nice looking steamers mike even without the lantern... [^]
                              • Frank and Bob,
                                Thank you both.
                                Frank, in this photo of a Shinohara turnout . . .
                                . . . you can see the two gaps to the left of the frog. The frog and points are all one unit and the two points have the same polarity. This unit is electrically isolated from the stock rails. This means no short, but it also means that the open point and nearby stock rail have opposite polarity, a problem if a wheel spans the gap and shorts out the system. This is not usually a problem with DC; there might be a small spark but the momentum of the loco and brevity of the short carries the loco past the point of the short. Not so with DCC, which shuts down with even very brief shorts. Therefore these turnouts are considered NOT "DCC friendly." Because my locos are small and I use no. 6 turnouts almost exclusively I really do not have this problem.
                                The advantage of this turnout is that there are no dead spots, even without the slide switch if point rails snuggle nicely against stock rails; they usually fail to do so at some point, hence the slide switch.
                                Bob, the slide switch just barely slides enough to throw the turnout and therefore I don't need a spring. To avoid shorts as explained above, the Shinohara turnouts are built to have an unprototypically-large gap between the open point and nearby stock rail, therefore requiring a significant throw.
                                On the other hand, on the Micrengineering turnout . . .
                                . . . points are isolated from each other and from the frog; note the four gaps that isolate the frog and the plastic tie bar. Each point is wired to the adjacent stock rail, preventing shorts if a wheel bridges the gap between the open point and nearby stock rail. As a result the frog is dead and must be powered by an electric switch if necessary. It isn't necessary for my consolidation but is for my 4-4-0. This kind of turnout is said to be "DCC friendly."
                                The throw on these is relatively small and actually less than the smallest mini slide switch I have, so the little "V" shaped spring is needed to take up the extra throw of the switch.
                                I hope I didn't go overboard on my explanation. If you reached this point, thank you for your attention and patience.
