[^]Thanks for supplying us with the slate roof particulars Mike. So out of the many described, which one is your favorite? That sure is a very fine looking slate roof on your building'..and your car as well'..id="blue">
As long as I was thinking about ridge caps for slate roofs, and needing one for the car shop, the auspices were favorable. My approach was to tape some 0.005" styrene sheet to the material Evergreen sells for making raised seam roofing, and using a sharp--but not too sharp--lead pencil I scribe the thin sheet . . .
Which when turned over gives me a series of ribs:
I cut them apart into narrow strips, folded them, and after painting I had ridge cap with the slightest suggestion of a bead at the peak.
I think for a railroad shop this is about as fancy as needed. Even when made of copper these ridge caps were often painted, so I decided to follow suit. Besides, Michael's did not have a nice copper color in a spray can. After a little Dulcote I will glue them to the peak.
Just stopped by to see what's happening. I've been wrestling with the Ramsey Station applying shingles. Tough for a first time through. Using Minuteman Scale Models slate shingles. I was wondering how the ridge gets done. Now thanks to your post the problem is solved.
Your roof looks really great. I'm going to have to decide if I ever do this again, and I will, whether to put the shingles on before installing the roof or after. For doing this the first time I think doing it before the roof is glued on would have been better. Oh well, I'm still in the learning stage on this portion of the hobby.[^]
Tony and Bernd, thank you for your kind words. They mean a lot to me.
Bernd, I found the slate takes practice, although I find them easier than the Campbell shingles. Almost all of my slate roofs have been removable; that makes it a little easier to trim edges and provides a firm support when sticking them down.
I completed the metal ridge and installed it on the car shop. A few more details--such rails withing the shop--and it will be complete . . . if I don't count the attached machine shop.
I don't claim this is the best method for ridge cap construction, but it does give a rather plain cap I think appropriate for this kind of building. If I were to do the same for a depot I would attempt a more pronounced bead along the top.
I have used the same method of scribing thin styrene sheet to represent raised seam roofing, such as on this feed store:
I go through this trouble because I find products like the Evergreen raised seam roofing to be a little over-sized and metal products are more work to paint and are easily bent in a nonprototypical-looking way.
