  • Turning out GREAT. Looking forward to the two you said you'd build for me.
    What? You didn't say that? Wait... surely I've got that email somewhere...
    Andre
    • "It predates Sgt. Pepper."
      That's nothing to sneeze at!
      • Mike, your Bobbsey twins are looking better & better with each new update.
        • Thanks guys!
          Bob, I suppose the purpose of boot guards was to prevent scrambled legs.
          Andre, you might want to look for that email in the junk folder.
          Bill, gesundheit!
          Greg, I was more of a Tom Swift fan.
          —Mike
          • Hi Mike,
            The two bobbers are a home run! Are you turning third and heading for home?
            Great work,
            • [^]Nice progress Mike'. The Bobbers are beautiful'..Excellent work Mike'..[:-propeller]
              • Thank you, Dave and Ted.
                Dave, the list of things to be done is getting short although every so often I realize that I am forgetting something.
                Ted, words like “beautiful” are nice to hear.
                • Mike, I can't believe I've been skipping past the "Early Rail Forum" and missing your great thread. Those cabeese are terrific.
                  • Frank, you are mistaken'....Those cabooses are BEAUTIFUL'...(LOL)[:-dopey]
                    • Frank, thank you for checking up on what I’ve been doing and for your kind words.
                      Ted, I feel I must be magnanimous and accept “terrific” as well.
                      • Trackwork continues.
                        I have reached the point where ties have been painted in shades of brown and gray and I have started carefully (and slowly) ballasting.
                        • I decided a jig would help me drill holes for grabirons. I try to construct jigs that I can use both for drilling holes and forming the grab.
                          I took care to make the jig reversible so that grabs for all corners would be identical:
                          Drilling the first hole; I snuggle the bit up into the little notch. That notch will be used in bending the grab.
                          Drilling the second hole:
                          To form the grab I make a right angle bend in 0.010" wire and stick it through the hole in the jig, holding it so that it lines up with the notch . . .
                          I make the second right-angle bend . . .
                          To get this:
                          The whole process actually goes pretty fast.
                          • Cool jig. Well done Mike!
                            • Nice work Mike. You're getting close to the finish.
                              It's only make-believe
                              • That's a fine jig!
                                Galen
