  • quote:
    Originally posted by railman28
    It going to look so good when your done.
    Bob,
    Thank you. Your machine shop construction thread of a couple years ago has been a real help, both for inspiration and methods.
    • Mike,
      Love the massive internal posts and beams with the use of the horizontal studs.
      This is going to be a great machine shop!
      • Dave,
        Thank you. Some of the post dimensions follow prototype, others are a little oversized to accommodate building the shop as a series of assemblies so that the roof and sides can be removable.
        • Somehow I have missed your threads before, probably because I haven't had a real interest in that time period (even though at my age I should ). Is this HO standard gauge?
          • looks great
            • Kyle, thank you.
              Mike, thank you for stopping by. Yes, HO standard gauge, although everything is so small I've had visitors to my layout think it was narrow gauge until I cleared things up.
              • I remember a few months or more ago, somebody asked about cutting mats, whether we used the grid imprinted on most. Was that grid really necessary. I recalled this conversation today while drilling holes in trusses for rods. It is not such a critical operation as to require a jig. I found the mat useful for lining things up, shown in these photos.
                I line up the base of the truss along a grid line, then line up my drill bit along a perpendicular grid line:
                Inserting the tie rod, I align the truss along the edge of the mat, again using a grid line as a reference for my drill bit:
                The result once the ends of the tie rod are trimmed:
                Not exact, but pretty darn good.
                Now if there was a mat marked off in HO dimension. Yeah right. That will happen about the same time somebody manufactures a metal scale rule with HO dimensions on all four edges so that however you pick it up you have the scale you need.
                • Well you impressed me enough with that tip to finally go get one. Sources?
                  • Bernd,
                    Mine is from Michaels. I think most art and craft stores sell them.
                    • Nice tip. How many rafters do you have to do? Gpod job here, a nice, but often overlooked detail, these compression rods.
                      It's only make-believe
                      • I got a mat with the same yellow-on-green color scheme from a tool dealer at W. Springfield a couple of years ago.
                        • quote:
                          Bob,
                          Thank you. I did a total of 8 truss assembles. Many more and a jig would have been the way to go.
                          I find the rods add a lot to a model, similar to nbw's on trestles etc.
                          • quote:
                            James,
                            Good point. I think I've also seen them at shows.
                            • I have a few mats of different sizes. Michaels, A.C. Moore, Hobby Lobby, JoAnns, all carry them. I got my last one on line (Amazon).
                              • Mike, I find I occasionally use the lines on my mat to keep things square - better than trying by eye.
