  • Bench work is looking strong and rugged. and yes, eliminate any protruding bolts, raisers and other causes of mayhem you can.
    It's only make-believe
    • Mike, just give those bolts a hair cut'..Nice bench work BTW'..[^]
      • Mike,
        Bench work looks great!
        I'm looking forward to the build of the E.D. Clapp structures. Very interesting design and should be fun to build.
        • Kyle, that's my power bus for DCC.
          Dave H., yes I have one healing now from drywall screw that poked through on old benchwork. Trying to not do that. Shorter screws these days.
          Bob, yes, good advice. Bears repeating.
          Ted, thank you. Buzz cut? Flat top?
          Dave, the wagon works is stalled for now but I will return to it when I've finished a couple of other projects.
          --Mike
          • Been weeks since I showed any progress. Yesterday I bought a sheet of homasote for the rebuilt part of my layout. My car shop is sort of on hold for now, but meanwhile I've started up on the general store again. With a reasonable push I should be able to wrap this up before too long.
            I have been building little sections such as the external stairs, a side porch with roof, and the front porch.
            Last night I added bracing for the roof. Since the bracing will be hidden, I like to use a lot to provide good attachment areas for the roof so that it does not pop up or warp when I glue on the roofing material.
            I've had a lot of work travel and a little recreational travel but that is nearing an end and I hope to get more done in the weeks ahead.
            • Mike.
              Nice looking building. Some good heavy bracing you have in that building. I'll have to remember that when I get around to do buildings.
              • quote:
                Thank you. Since you will no doubt be using brass I expect you will need less bracing.
                • Michael, Looks good! General stores are neat kinds of structures. I have one on my layout and unfortunately only room for one, otherwise there'd be several
                  Will yours have an interior?
                  • Bill,
                    Thank you.
                    I find general stores interesting too. One of my first scratchbuilt structures back when I was around 10 yo was one of the false-front variety. It was based, I believe, on an article in Model Railroader. That was when I was interested in western scenes, although there were certainly lots of false-front buildings in the east.
                    I'm thinking of doing an interior. It might have to wait while I get some other models completed and my layout rebuilding further along. It would not be the first time I've gone back and upgraded a model. I'm going to do the foundation in such a way that I could add an interior later.
                    • quote:
                      Got a good laugh out of the "using brass". (I need a emodicon rolling and laughing on the floor) Although Mike's right it would need less bracing. I guess I'm going have to build something in wood. I've got a kit coming. I'll be posting on that when I start on it.
                      • Bernd,
                        I'm looking forward to watching.
                        • Nice to see a little progress Mike'. Let's get er done' Looks like a great store in the works with a hurricane proof roof installed'..
                          Okay Bernd, this will be your second wood project coming up that I'm aware of. So, I'll be lurking there `Partner'..[:-cowboy]
                          • Ok, here's another push. I like this store let's see her finished.
                            • Alright already!!
                              I worked on a handrail for the outside stairs over lunch today. One half of the roof is glued on and I started shingling. I have an out of town trip and will take it with me to work on. Better than the tv.
                              • Might not look like much has happened, but I am moving forward on my general store. Lots of travel and busy evenings the past week, but I made some incremental progress.
                                The subroof is on, scribed siding primed both sides. The scribes guide placement of paper strips representing cedar shingles purchased from Bar Mills. Old photos show very even rows of shingles so I did not glue the strips down with the uneven edges revealed as intended by the maker (I assume).
                                I have made parts for the foundation, painted the two chimneys, built a handrail for the stairs from styrene, and primed some details.
                                The chimneys are not glued down yet and the building is just sitting on the stone foundation.
