Hi Jeff, I have noticed the same slow down. I will get busy this week end.
2'x3' Cork Board Challenge
I have been trying the templates and a sample of street track. Here is the progress. This track requires patience and I may need to switch to plywood to build the layout to secure the track. It would still be 2x3. Turnouts are 10" and I have run a black beetle drive around the test track.
Larry, I've never seen that rail before. How are you fastening it down?
The Pliobond sounds better than super glue to me too. That rail looks interesting.
Larry, that's a great track plan, I'm really looking forward to seeing what you do with it.
I mentioned elsewhere (http://www.railroad-line.com/forum/t...TOPIC_ID=43199) that I've got a couple pieces of motive power started for this project, which means the scale/gauge has beed decided on, as well as a theme. I'm planning an On30 electric tramway based in some tropical place, probably an agricultural line, sugar cane most likely. There will be some ramshackle passenger operations too I'm sure. I am going to keep on with my dystopian idea too, but it will be subtle.
Like I said I've already got the board and a bare minimum of track, I just have to start laying it down..!
-Cody
I'm not trying to enter, but thought I'd show this small N scale layout I built based on this: http://www.therailwire.net/forum/ind...?topic=32315.0
It is 16"x26":
This is HOn30. 13.5"x24":
https://www.youtube.com/watch?v=UbhA16PaGdE
I never finished the HOn30 layout though...And then I copied it down into Nn3 9"x16" !
https://www.youtube.com/watch?v=-pQ9nC7hsKk
Actually the the HOn30 and Nn3 layouts were copied from a On30 2'x3' layout I started a long time ago. Second entry here:
http://www.carendt.com/small-layout-...special-issue/
