Great to see progress.
2'x3' Cork Board Challenge
Thanks guys. Few update pics. The lower cliff is started. The dark band is a layer of cork to represent a different type of sedimentary rock.
With and without the flash. After the glue sets up, I'll go back and fill some holes and pick at it a bit.
Here the bin is set in place.
If anyone has done this type of ceiling tile rock, I'd sure like to here from you. I found a great tutorial from The Pacific Coast Liner http://www.pacificcoastairlinerr.com/more_rocks/ Other than that I'm flying blind.
Cheers, Heath.
Thanks for the kind words and encouragement, gentlemen. A little experimenting. The Pacific Line tutorial recommends that the tile be sealed with paint primer. I did not in the sample. I did 'soften' the rock by adding some water the the surface prior to painting with cheep artist paints, black base and light dry brushing with yellow and grey, as suggested.
The upper portion has had more water treatment then the lower.
I like the upper portion, it has more of a sandstone look. Just need to figure out the paint. I would like the colour of the rock that is found along the Niagara Escarpment. I not modeling any particular region, I just like the look of that rock.
Thanks for checking in,
Cheers, Heath.
