Ever since I first tried switching with a sound-equipped loco, I've been on a quest to match the prime mover noise with prototypical switching.
The first problem is getting the prime mover to rev up before the loco starts to move. Most engineers throttle up to at least Run 4 when light, Run 8 if coupled to anything heavy. The slack doesn't even run out for 5 seconds or more.
Some sound decoders support manual prime mover notching. I don't like this because I have to keep track of both notch and appropriate speed. All very well if I'm putting on a show for somebody else, but not so hot if I'm the audience.
In the Bachmann RS-3 and the Atlas HH-660, you can get a tolerable approximation by setting a rather slow acceleration rate and throttling up to speed step 25 or so. With Athearn's Genesis GP-9, acceleration rates slow enough for the diesel to rev before movement aren't very practical when doing actual switching.
The second problem is what happens when the loco gets rolling. Working in level yards, the engineer almost always throttles back to idle and drifts along until it's time to apply the brakes.
Some people do this with manual notching, but see above. None of the decoders I've tried can address this with the deceleration rate; in many cases the prime mover RPM is tied to the track speed.
So I was quite interested when MRC advertised decoders with an operating brake function. It sounded like I could prototypically open the throttle to accelerate, shut off to drift and apply the brakes as necessary.
