Replacement Motor Source
  • Replacement Motor Source
    I just bought an older P2K GP38-2 locomotive. The motor is a real screamer. I have tried oiling it but it doesn't quiet down. Through a search, I found this is a common problem with this model. Any suggestions on a replacement motor and/or a source for motors. I don't want to put another P2K motor in it. The dimensions of the flat can motor in it now are 22mm high x 18mm wide x 32mm long (approximately). Every place I have looked, the prices for a motor are about what I paid for the locomotive.
    Thanks.
    David
    Any company that has a good motor will cost you. NWSL has some of the best, see here; http://nwsl.com/uploads/chap2_web_01-2014.pdf
    Also, one of the best to ask this question is to Denny, Forum member (CWRailman) he has done many motor replacements and knowledge about them.
      Denny certainly is a great resource.
      I get my motors from LocoDoc or Hollywood Foundry:
      http://locodoc.com/
      http://www.hollywoodfoundry.com/default.htm
      Thanks Cameron
        David, Did you run just the motor? I have had these engines make that same noise but it has been the bearings for the worm gears on top of the trucks.
          I've heard that these folks make good stuff for repowering. (No personal experience nor connection with the business)
          http://www.alliancelocomotiveproducts.com/
            No, I didn't. I will have to check that out before I go any further.
            Thanks.
            David
