Large scale Indoor layout
  • #91
    Ty, those partitions between the lights work great. Nice going. :up:
    • #92
      The front and rear lights with the foam partitions provide terrific lighting on the RR and the backdrop.
      • #93
        Havent been on the forum for a long while. Just like to say this layout is looking fantastic. Keep up the good work.
        Owen Pass Lumber Company
        HO Logging Layout in a Shed.
        • #94
          Thanks Guys,
          Its been a busy week or so but finally got to do some more work on the layout.I have been trying to get up to my grandfathers shop to get more wood to make the ties for the turntable. I have been looking at the prices of dimensional lumber and its too expensive for me seeing over the next year or so I may need a lot of it.
          So I thought about cutting it my self. I have a 15 y/o table saw that has seen better days and I have been looking for a newer one for a long time. I was out at Lowes the other day and they had the New Kobalt table saw. It was reasonable so I figured I would try it out. While I was there I bought a 60 tooth finishing blade.
          I brought it home and set it up. I made a new Zero clearance throat plate for it so I could cut really thing wood. I had some Cedar to try it out with .It cuts wood very nicely
          • #95
            Nice !!!
            • #96
              I was going to post more pic's but got running late for work this morning...
              I cut all my ties for the turntable and dyed them with a alcohol/shoe polish mixture. I let then dry and then I used wood glue and glued them to the previously marked positions. I had also prebent the rail I was going to use. I then spiked it all in place. One piece of rail was not long enough to go all the way around. So i did have a shorter piece. I added an extra tie at the two places it joins and it matched up perfectly..
              Ty
              Yes I know the ties look a little tall. But I had to custom fit them so the track would meet with the upper deck correctly. This area will be back filled with ground cover later...
              • #97
                Works for me. :up:
                • #98
                  Looks impressive to me. Finding this inspiring that may result in a large scale layout.
                  • #99
                    Thanks Guys...
                    Next I went and cut the timber for the retaining wall. After it was cut I roughed all the pieces up with 36 grit sand paper. I then colored them with the alcohol and shoe polish. first I did it with
                    black and after it was dry. I did it with Brown.
                    Here are the pieces still wet.
                    They lighten up when dry..
                    • Next I figured how high I needed the wall to be. I made spacers to raise the wall to the correct height. Once in place I stared laying the timbers and gluing them down with wood glue.
                      • The retaining wall looks really great. I have been looking for some approach that gives the weathered creosote look. You really captured the look and feel. I am preparing to start on a Chama coaling tower but delaying to find a stain approach that gives the weathered appearance. Thanks for the hint and the inspiration.
                        • When you are using the the shoe polish and alcohol mixture you should play with the ratio. It can get too dark quick. Also roughing up the wood helps with the wood accepting the stain. The wood was only in the mix for about a minute..
                          I am also using a cedar that is really light in color
                            • Thanks for the advice. BTW, how long is your turntable? Can it hold a K-37?
                              • The largest think I have is the 3 truck shay and it is about 30" the turntable 31".
                                Ty
