Nice job on the portal and retaining walls.
Large scale Indoor layout
Speaking of ground cover.I have been working on the hill between the trestle and the bridge.
I added some static grass and a mixture of scenic express ground covers to the parameter of the area and then a mixture of Scenic Express dead fall and Sheet Moss that I ran through a food processor.
I was trying to figure out how to slow the curing of the hydrocal and ran across this in a unrelated forum .If you are mixing this up or any plaster mixture you can add a few drops of Lemon juice to the mixture and it will prolong the curing time. I have used this on the homemade sculptamold and on hydrocal just by itself. Just hope my wife does not miss the lemon juice...I continued with the sculptamold and covered the base below the trestle. Before applying the homemade sculptamold i painted the area with white glue to help with the adhesion to the foam with such a thin layer..
