Large scale Indoor layout
  • Well the next thing was to draw out the radius on the layout so I could cut the temporary pieces for trestle area.So I took my string and a pencil and started drawing out the curves. One problem I had was I am gong from a 9' diameter to a 8' diameter. The problem is making that curve transition. So here is how I did it.
    Where the curve was to start the transition I came out from the pivot point and add a nail that the string would hit . I moved the nail until it reduced the curve to fit the area. Then I added another nail further out to make the curve even tighter. by doing this I had a nice even line all the way around the curve.
    • Once I got all the radi figured out I put the track together and made sure everything worked well. Once That was done I wen ahead and put down a base of 1/2" foam. I then wired it all and it worked great.
      • Landrel, I've just perused the 23 pages of your thread. Your new layout is expanding beautifully. I love running the trains in the garden of a friend's layout up here in Canada. What a dream it would be to run that scale indoors, like you are constructing. Magnificent effort thus far! :up: :up:
        • Thanks Mike for the comments. I have really been blessed with the room that I have. Since I added the workshop area it really opend up for the new expansion..
          • Ok guys,
            I was so excited to have it all togther and ready for a complete test run. That I took my Bachmann rail truck and figured if that made it around I would have no electrical problems...
            This shows you how the first run around the layout turned out...
            • Ooops!
              • OMG, I missed a couple of days and I missed almost an entire layout build. Nice going Ty.
                • Thanks Frank.
                  • Next I figured I should camouflage the 2 poles in the middle of the room. I first moved the electrical outlet to the top of the poles. I then primed both polls and painted them the 3 sky colors I use. From dark to light. I then went back and painted them the foliage colors. I use a Medium yellow and a paynes grey. I may have to paint higher on the poles but we will see when we get there..
                    • Comment
                      • Hummm, trees and sky, you didn't want to go with a Minute Man missle park?
                        • Frank Your so right. Just a couple fins and a little paint and I would be ready to go...
                          • Well while just thinking about thus addition. The local Middle school was having a new roof put on. They are installing a metal roof over the old shingles. Part of putting the new roof on was putting down a layer of 1"of foam board.. Well I went by the site and talked to the foreman and asked him if I could have all of the the scrap foam board. They were cutting off large corners and sometime throwing away 1/2 sheets. so I have collected about $400 worth of foam over the past month..Well if I had to buy it that about what it would have cost me...
                            So I have been putting down a full covering of foam Board.
                            • That's my kinda guy, save money when you can.
                              • It's coming along nicely!
