Steel Caboose for the C -and- R
  • #16
    Here's some progress photos that I took an today. The door fits fine, but I need to file the frame down so it won't close so tightly. The other end wall and door is in the works and I'm letting the glue dry (geezer code for nap time ). The railings have NBW details on the ends and trim for the curved tops and wall corners will be put in after the roof and side walls are fitted to clean the edges up.
    Russ
    • #17
      :up:
      • #18
        That looks like a good solution, Russ.
        • #19
          I started to work on the roof this evening. I made a couple of wood pieces cut at the roof radius that I want and glued them in place to hold the shape of the roof. These pieces fit into the slot between the outer and inner walls of the end wall. it fits well and will allow th roof to be removable.
