Started in on the next one - maybe not that big a salvage operation, but.....
3 dome Lobaugh tank car that was in need a bit of help. Someone had dropped it (I guess...) and popped the frame apart on the one end corned and popped the end tank band off. Just happened to have some extra Lobaugh bits for the band. Just an exercise in getting everything into locked and clamped into place and soldering it all back together. Thought I'd have to use my iron to avoid popping bits off, but not enough heat - called in the torch and all was good. Ruby flux and good solder and it's back together!
Yup! Kit older than I am. Every so often you see one for sale NIB and ready to be put together....picked this one up cheap thinking it was not mortally wounded and one that I could put back into service. Might do some other upgrades; missing a brake wheel and staff ; no hole for it so just skipped? Grabs leave a lot to be desired, but I might replace most if not all of them. Also needs a good scrubbing with lacquer thinner,
Nice soldering. Having recently spent an hour climbing around a 1:1 tank car getting its brakes released, I find the relationship of the handrail around the end and the end-sill dangerous, even if prototypic. My butt would be out beyond the coupler while I did hand-over-hand on the rail.
Thanks on the soldering! I started out with my iron but it just did not have enough zip so I flashed in with my little torch and got the end together.
Pretty sure that the handrail stanchions of 70+ years ago on these cars were a smidge long, Upgrading here and there, but given what this model is I'll reach the point of diminishing returns and cost balancing fast.
With a bit of luck, I should be able to get it done very quickly working around the weather, etc. Got a pair of old metal Athearn Andrews trucks for under it set aside, too.
