Beautiful work, as always! Hard to believe this is HO scale.
The freelance California Railway -and- Navigation Co
:up: +1!
Originally posted by railman28
The reins are looking fabulous. And those horses have bee trained good too to stand there with all that train noise without an attendant or being hitched up.
. I can recommend the tape method. I think Rich (Pennman) also had tested it in HO.
Thanks Dallas and George!
Thanks Dave, I'm happy you like it. I feel very humbled by your and Frederic words.
Hakan
Hakan,
As everyone else has stated, your layout has truly been an artistic adventure... :up: :up: :up: :up: :up: , and I also think that your reigns look a little better than mine. I like the way masking tape sticks to itself and makes making the reigns much more lifelike than any other material. YOU HAVE DONE AN AMAZING JOB ON YOUR LAYOUT. Everything in every scene looks so real. Keep up the good work and more pictures!
Thanks Guys!
Not much has been going on apart from my Frateschi 2-8-0 project. I decided to mount it on to a new mechanism and yesterday a package with an Roundhouse 2-8-0 arrived. I got it at a good price on Ebay and I'll use it to get the Frateschi running. I was a little disappointed when I tested the Roundhouse loco as it didn't run very well. But I was in luck and after a examination the fault was that it was too tight between the crosshead guides. After bending them apart the loco ran just fine.
Hakan
Thanks Martin!
I thought I show what I'm after with my 2-8-0 kitbash. I have two photos that I'm using for inspiration. The first one is from Kinerts book Early American Steam Locomotives and the other one is from Abdils book A Locomotive Engineer's Album. I'll try to follow mostly the one in Kinerts book with the exception that I'll put the air pump on the right side and backdate some details for example the pilot. The photo was taken 1910 so there has possibly been changes to how the engine looked 1883. I'm a little skeptical to the build date as the loco looks more like it was build around 1890.
From Kinerts book
From Abdils book, Baldwin built 1893.
I'll use this for inspiration on the livery.
Here is a photo showing the various parts.
Luckily the Frateschi boiler fits over the motor on the Roundhouse one. I was a little afraid that the boiler would sit to high as I want a low look to the boiler like in the Kinert photo. From the Frateschi I'll use the boiler, cab, siderods and guides. The cylinders looks a little peculiar so I'll try to adapt the guides to the Roundhouse cylinders. The cab will be changed, it is quite larger than the Roundhouse one which is what I'm after, by adding more windows and a wall at the back. As it is now it is open at the back. On the tender I'm thinking on using the Roundhouse one but swapping the tender shell with the Frateschi. On the pilot I like the colonial look on the Frateschi but it doesn't look very American. Anyhow it is to small and I'm thinking on swapping it to a white metal one I have from another project.
As seen on the photo below the mechanisms are quite similar in size. The Roundhouse drivers are a bit larger but not by much. The Roundhouse chassis has the Frateschi cylinders. I widened them as the side rods touched the guides
Hakan
