Tellynott corner module
  • Hi guys.
    Thanks for your comments George, Martin and Greg, they are always appreciated.
    I've been chipping away at the new factory so thought I'd share a couple of shots of where I'm up to.
    Walls are all finished and mostly assembled (the front extention is still just sitting in place, as is the addition to the right). Windows and door are not fixed in yet. Brickwork is painted up for the stack to sit on and the foundation to the left, but not yet assembled. Had to think a bit about how to make the right end addition rubust and stay straight when it is only about 1/4" thick. I'll reveal how I did it when the structure is fully assembled. The colours are more of a contrast than in the pics. Main colour is Floquil earth, trim is Floquil roof brown. Lots of rafter tails coming up!
    More soon!
    Cheers, Mark.
    • Looking good! Following along ... continuing to find inspiration ... sometimes even visiting between posts.
      Dallas
      • It for my a very fine inspiration i likeit ,looking great
        Greeting form Germany
        Frank the Cowboybilly
        • Hi Guys.
          Thanks for the comments Frank and Dallas! Dallas - that really means a lot - thank you!
          Well, progress has been taking some time, but progress there is none the less, so here is an update.
          Still a little way to go. I've been looking at signage today and working out what this structure will be. I have settled on 'Edmonds Baking Powder' with the iconic (at least in NZ) catch phrase 'sure to rise'. I have built a stack from plastic tubing, which has been painted and is curing. I need to add tar paper roofing to the small boiler house roof, and the right end addition. The corrugated iron roof will be toned down with some white chalk. It was primed grey, then painted Floquil gun metal followed by caboose red and then dry brushed with antique white. There were some splits in the weatherboard before I started, and although I glued and taped these together, they have come apart again. These will have to be discuised. I was intending to have quite a bit of ivy growing up the building anyway, so will be able to hide the splits one way or another. Here are some pics.
          Firstly, here is one showing the bracing. You can see I put a couple of pieces of brass tube in to try to keep the structure plumb and true, as the extention to the right is only about 1/4" thick. Actually I had thinner wooden bracing ready for the verticle strengthening of this addition, and then promtly forgot and put thicker stuff on. When I realised my mistake I decided the easiest way to rectify the problem was to make a stop and hit the bracing with my electric planner! It took but seconds, but I was glad to be done with it and still have my wall intact!
          Here is the structure in position on the diorama.
          Ok. For some reason I cant upload the other two pics I prepared, so I'll post this and see if I can post the others in another post.
          More soon, cheers, Mark.
          Close Window
          • Hi again.
            A view straight on.
            And one from the left.
            Back to the signs!
            Cheers, Mark.
            • Your Edmonds baking powder is really looking great Mark!
              I can't wait to see all of the extra stuff installed on to it.
              • Mark,
                Although I haven't posted on this thread I've enjoyed following your progress - you ability to create the impression of a bustling big city in a minimal space is inspired and reminds me of Earl Smallshaw's layout (which I've seen in person several times).
                You mentioned looking for signage ideas for your block of modified Magnuson stores - one neat image from Jack Delano (available in the US Library of Congress collection) is this one showing all the headlines of the day obviously handwritten and posted in the window of a newspaper office/newstand in Brockton, Mass.
                http://johnlrobinson.com/wp-content/.../newspaper.jpg
                May provide some inspiration?
                Keep sharing your modeling, and I'll keep following!
                Marty
                Marty McGuirk
                Manassas, VA
                www.centralvermontrailway.blogspot.com
                • Hi guys.
                  Thanks for your comments Greg and Marty - they are always much appreciated. Thanks for that link Marty - I have something very similar to this in mind. The sticking point is finding appropriate prices for everyday goods in 1932 New Zealand. I have found a good site and just need time to sift through it - my next project.
                  Well, Edmonds is all finished until it is time to set it in place. I will put some ivy growing up the walls to hide the worst splits in the siding when I do this. It will need a small walkway to the doors and probably a few small details as well. It was a fun project, and i think it came out quite well. There certainly wont be any others around like it!
                  Here are some pics.
                  An overall view with the forground structure removed. I'm thinking of making this forground structure (a Magnuson brewery kit-bash) part of the same complex.
                  From the left side.
                  A close up of the left end. It was that sign writing on the original that was the clincher for what this structure turned out to be.
                  And a close up the the right end and the stack.
                  • Lovely structure Mark, like the different rooflines..
                    • looking good Mark. I like the billboard letting on the side of the building.
                      It's only make-believe
                      • Very nice, Mark. I'm looking forward to seeing what your next building will be.
                        • Mark,
                          I love the lettering on the building, is it dry transfer (rub on) or waterslide? The sign on the roof is great too.
                          Ralph
                          Growing Old is Mandatory
                          .... Growing up is optional!
                          • Really excellent work Mark!
                            The Edmonds rooftop sign is a real eye catcher.
                            And I bet, this will look even more fantastic once installed on your module.
                            My only complaint, I don't see a light anywhere! :erm:
                            • Hi guys.
                              Thanks for the compliments Martin, Bob, George, Ralph and Greg, they mean a lot.
                              The signage on the walls is done with Woodland Scenics dry transfers.
                              Greg - yes, you are right. I will look into it. I have to start eventually!
                              Heres a couple more pics showing Edmonds in context with the mock-ups around it. The brick work and bottom of the stack will barely be seen (only glimpsed at an angle) so I did not spend much time on this area (none of the brick corners were puttied and sanded as is my normal practice) and no details were added. This is one of the main reasons why I mock things up first - so I know what will not be seen and so what to not put much effort into.
                              Close up of stack looking through Magnuson Brewery kit-bash. It is this structure that I am thinking of making part of the Edmonds complex. If I do I will add a walk-over between the wooden and brick structures. The prototype had both a large brick and large wooden building.
                              From further back. Brett's Brewery in the forground, Magnuson Brewery kit-bash behind, and modified Hollenders boxing gym to the left.
                              And one looking straight on.
                              Cheers, Mark.
                              • This is really going to be a stunning piece your (Tellynott module) when completed Mark!
                                As you fit each structure into place I get more excited to see the next!
                                Now stop reading this and get back to work!
