Hi guys.
Just have to try to get my head around adding photos again.
So here is a photo of the kitbash coming together. You can see the internal 'fin' of white styrene. This was added to get the warp out of the wall. The factory 45degree edges seem to be put on these walls with no thought of addressing warped walls. This means that when you do address them you end up with an edge with curve in it. I filled this straight and then doctored the 45degree bevel. Of course, if you were building this as per instructions and did this, the kit would no longer go together square, as the wall(s) you doctored would be shorter.
More soon, cheers, Mark.
