Curious if anyone else has had an issue like this. Purchased a Walthers 90' Cornerstone Series Built Up Turntable last spring. Finally got around to detailing and installing it this fall. Upon attempting to set the indexing, the unit stopped functioning. Power was going to the control box but nothing was being transmitted through the control box to the motor which operated the bridge. Bridge track had power but that is wired to the layout track bus.
Spoke with the tech people at Walthers and they suggested cleaning the conduction plate and points, checking the gear for debris, etc.. Nothing was found so they concluded that perhaps in hooking it up an improper power connection was made which damaged the control box. Sent it in with a check for $32 and it came back a few weeks later. No explanation came with it. Hooked it up, being meticulous about how everything was done - completely proper connections, dedicated power source of the correct amount - everything! Results? Exactly the same thing happened again. Operated briefly then nothing.
Anyway, I wonder if anyone else has experienced issues with this product. Before purchasing, I read quite a few favorable reviews and I was pleased with the apparent overall quality of the model. It also looks good. Just wished it would work!
If Walthers doesn't have a suitable solution I may just say to heck with it and look for a different brand. I'm considering the AAA Turntable. Pricey but if it works I'll be happy.
Would welcome any thoughts as to what the problem might be along with other feedback.
Thanks,
Dan/researchhound
Thanks,
Dan/researchhound
