  • #91
    Very nice work Karl, I can't wait to see how you tie it all together at the valleys. Pat
    • #92
      Thank you all for your posts and kind remarks, after just getting home from a long hard day at work it is very nice and encouraging to read them all.
      I really dont have any castings Mark, just a few of my barrels and drums I made last year and a few other small odds and ends. I will probably end up scratching most of the interior stuff that I need.
      I actually had the attic trusses glued in place this morning Pat before work but, decided to add in another detail dimension so took it apart again, I plan to work on finishing that area this evening, after I eat.
      Thanks again,
      Karl.A
      (incidently the colour in the last pic is 'almost' exactly accurate. The flooring isnt quite as 'contrasty' as it appears in the photo but it will be blended a little further with chalks.)
      • #93
        During one of your builds you said you had to stop to cut more stripwood.
        How do you cut it and what do you cut?
        John K
        John Kerekes
        Graduate, summa cum laude
        • #94
          John, I just finished posting an explanation of this method in the "trackside diorama" thread...
          Here is the link...
          http://www.railroad-line.com/forum/t...3&whichpage=15
          Let me know if anything isnt clear.
          Karl.A
          • #95
            Oh, belay that Karl. A!
            Found it elsewhere
            Thx
            John K
            John Kerekes
            • #96
              Well, I finally got a couple of hours at the model bench tonight after a gruelling work week. Not much progress but a hurdle overcome nonetheless.
              May not be 100% prototypically correct, but, it looks about right to me....
              Karl.A
              • #97
                I have been so engrossed in deciding how to do the connecting rooflines that while I was just reviewing my previous post I realised from the pictures that I have completely forgotten to build and install the handrails !!!! :erm: :erm:
                I forsee ALOT of cussing in the near future, (even more than usual ) as I try to get them in there straight and looking 'right' without too much damage. Oh well.
                • #98
                  You know what Karl, this is prior to all those safty regulations, maybe they did not have any safty railings.
                  • #99
                    Karl
                    Framing: par excellence!
                    • Thanks for the plausable 'get-out-clause' Mark, but, I want them in there to add to the detail factor, I think it will also make the construction more intricate looking and interesting, atleast that is the idea. .
                      Thank you for your kind words Peter.
                      Karl.A
                      • quote:
                        Great idea Karl, because as you can see from all the responses above, nobody is particularly impressed with how intricate it is already!!
                        But seriously, are we talking wooden railings here, or do you have some other cunning plan?
                        • Thanks Simon
                          Yes they will be wooden railings like the ones down below in the split level area, but, they will have a 'wire mesh' installed to prevent any stray items rolling off the attic floor and hitting an LP on the head below. Also, after I get them installed in the tight space I will be trying to add some horizontal bracing attaching them to the trusses, for vertical stability.
                          Karl.
                          • Karl, I'm not sure how prototypically correct your joists are either, but they look good to me. :up:
                            • Karl, I've just gotten caught up with your updates posted over the last several days. The level of detail in the roofing/rafters is just stunning. The whole model is absolutely contest and museum quality.
                              • Karl,
                                I think if you build the rails as an assembly and slide them in place, it'll work fine.
                                A helpful hint would be to put a bottom plate on the rail's assembly, offering more gluing surface.
                                It is prototypical to make up railings that way and install them after the flooring is down.
                                This info is just in case you didn't know this already (which I'm thinking now, you probably do)
                                Dave Mason
                                On30Kits.com
