For a few years, I've been wanting to construct a shelf layout that does not infringe on floor space and allows for bookcases to be constructed underneath it. I came across an article by Bill Darnaby in a early 90's MR that showed a wall bracket that he designed to hold up a narrow shelf. With some modifications, I built a few of these over the weekend and attached them to the wall. They are more than strong enough - I can almost hang on them.
This is one side of the bracket:
and the other:
Wide shot of the layout so far. Once the fascia is installed, there won't be any brackets visible, and there will be plenty of room under the layout for bookcases, etc. I'm experimenting with how big of a span I can have with the foam.
What do you think?
and the other:
What do you think?
