Hi All,
I have a bit of a problem and wanted some feedback from the experts here!!
In the following two pics, you'll see that the back tracks are elevated and the plywood deck is exposed. I need to put in some type of retaining wall along this area. There is not a lot of clearance between the trains on the lower track and the upper deck plywood so whatever I use will have to be pretty thin.
I was thinking about using the Bragdon cutstone casting that I have but I don't think it will work since I'll have to make the casting so thin that it will probably break as I work with it.
My next thought is to use some type of embossed plastic sheet with a cutstone or similar design. That would certainly be thin enough.
Another thought would be either a wood or concrete retain wall. Being a heavy mainline in the mid 50s, would wood even be appropriate?
So do you have any suggestions? I'm definately open to any that you may have. That includes any actual products such as embossed plastic sheets (maker and item # if you have it).
Thanks much in advance![^]
