I'm sure I should post this somewhere else, and I'm sure the subject has been covered before, but I don't know where on both counts so here goes.
I would like to mount some tortoises in areas of the layout where the turnout is some 4 inches above the benchwork where the tortoise is mounted. I had purchased some long lengths of piano wire (or whatever you want to call it).
The problem is when the tortoise moves the actuator rod does not move the turnout. I'm guessing it's just bending and is not strong enough to move the turnout. Is the solution as simple as getting thicker wire or is it something more complicated?
Any help would be wonderful...pictures of anything complicated would be great.
Thanks,
Dave :erm:
Thanks,
Dave :erm:
