I have been accumulating some kits and locos for some new builds for me. Rather than do a new topic on each, I will add them here to share and perhaps stimulate your curiosity.
TomM's Stuff
Hey Tom!! Great start on a "Stuff" topic. Your reasons are the same as mine...Would be too hard to keep track of all the topics.
I like the idea on this build.....will it have room for a decoder?
Maybe a small speaker could be hidden in one of the side tanks...Put a top
on them & leave the side next to the boiler open....JMO
This one should be interesting.
OH Yeah! Les finally got me goin with the PR-3....boy, am I dumb!
Second project:
To modify my Bachmann Climax with the "Steam in the Bush" Climax cab kit:
The locomotive has been dropped to the floor, only once, and still runs. Must find the headlight ....
On30 "Steam in the Bush" Climax Cab Kit which included a steam winch, gypsy and hand brake.
My finished project may look like the one shown in the link:
http://www.ozsteam.com/html/on30_climax_cab_kit.html
Tom M.
Tom
I am really looking forward to your comments on this kit and the project. I want to build a Plantation Forney (given to me by Mr. Bachmann for such a project). I guess it would be bush forney then.
What I am interested in is how the vertical supports anchor to the floor.
How the roof assembles..I see the link so that helps.
BTW...I also dropped my beast to the floor, only broke the front pilot board, the light flew off, but I recovered it. So that makes them flying....
Les
I need to remove the gear from the motor on the left and install on the motor to the right. I do not have a puller nor can I get one quickly. I tried the slot in the hack saw blade but only bent the wire that I was using to push the motor shaft down through the gear.
Any other ideas. I will not be doing anything more tonight as it is dinner time so I look fwd to suggestions.
Tom M.
Suggestion: Use some heat to free the gear. Just dont melt everything!
MicroMark sells a great lil puller. If you have a tap & die set, make
yourself one. Take two plates and drill some holes, the center one on the rear being
just a bit bigger than the shaft of the motor. The front plate should have a hardened
screw to make it work. Better solution is MicroMark! LOL!
Good luck on this one.
