Benchwork
This is a sticky topic.
  • Benchwork
    Benchwork:
    This sticky will be for discussions on how to construct your benchwork. This will be for all scales. Please feel free to post any construction methods that you have found satisfactory to you
    Thanks
    The following was posted by Walt (Rusty Stumps) about the construction methods he is using. This is a very strong but lightweight system but does require the use of a table saw and a dado blade for your saw.
    Hey folks, the Fall Creek Lumber and Mining Railroad crew has been hard at work and the table framework is starting to come together real well.
    You can view a number of photos at: http://www.rustystumps.com/layoutconst.htm
    Hope you enjoy them.
    Walt
    Edit
    From Walt
    First, if you go to my website be sure to review all the photos on the layout construction. I've noticed a large number of people hitting the first page but the numbers drop off on subsequent pages and they hold a lot more information.
    Yes please make sure that you view all of the pages. There are 4 on framework construction and 1 more is a schematic drawing.
      The following is a page from a web site that I think was posted here at RRL but I am not sure who posted it. This web site explains with pictures the use of a hollow core door with metal studs and PVC legs. It is benchwork for N scale but could probably be modified for HO
      http://www.members.cox.net/metric8/Benchwork.htm
        John, I'll add a little here on my "I" beam constuction method. First, if you go to my website be sure to review all the photos on the layout construction. I've noticed a large number of people hitting the first page but the numbers drop off on subsequent pages and they hold a lot more information.
        If I were to start this project over today I would make some modifications. Instead of using the 1/2" plywood for the web, verticle piece, I would use 1/4" masonite. Understand that when a piece is trapped between the two rails it's strength is increased considerably. The two rails are mainly to keep the web (verticle) from twisting and also help keep it from sagging. As long as the web can be kept verticle and straight it will support a lot of weight. The 1/4" masonite is a lot lighter than the 1/2" plywood which is another contributing reason to use it.
        As you couldn't put screws into the edge of the masonite, nor is there sufficient surface to glue it, I would add a slotted tab piece of two pieces of 3/4" plywood glued up. With this style of constuction the "I" beams could be made to any length then just cut to fit. Then the tabs could be added for assembly.
        If anyone is seriously interested in this style of construction let me know and I'll make up a sample beam to demonstrate my point.
        Walt
          For those of you that may be interested in building modules this web page was posted by Railway Bob. It explains modular construction with pictures. Very informative. Click on next at the bottom of the first page to get to more pages of construction techniques.
          http://www.railwaybob.com/Modules/Mo...odConstr01.htm
            Here is another discussion http://www.railroad-line.com/forum/t...?TOPIC_ID=2813 using Pink or Blue foam.
              Hi John. Thanx for the promo to my website. I've also got instructions for building legs using rigid ABS plastic pipe, how to build "carry-plates" to transport your modules, installing your LocoNet if you use DCC, and tips on installing decoders. In the works are instructions for making wooden legs for your modules which will be up in the next couple of weeks.
              Hope you all enjoy.
              Have fun. (I am!)
              Visit "Railways of Eastern Ontario" at
                Hi
                Here is another web site with benchwork using a different technique.
                http://www.webreb.com/HiRail/benchwork.html
                  Gentlemen: I urge you, in all instances, to use screws to assemble benchwork, instead of nails. It is much less traumatic to existing plaster and scenery to unscrew a board, and replace benchwork with screws, than to inflct pounding nails into existing work. Scale earthquakes have the same effect on models as real ones do on the prototype.
                    Wallace, good point and I totally agree. Screws don't cost that much more than nails, especially the drywall ones. That can save you a lot later on if you want to make changes not rebuild which is what might happen if you use nails.
                      Hi all
                      Here is an example of using Cookie Cutter Construction method for your benchwork. This was originally posted by Shamus (Paul) in this forum.
                      Posted - 08/18/2002 : 05:45:06
                      Here's a starter, letter (A) shows the cookie cutting done on both the 1/8" plywood and 1/2" insulation board. Letter (B) shows it in place but not raised and letter (C) shows part of it raised ready for the next job.
                      PaulT
                        Here are a few pics showing a method for using 1/2" blue foam in the "cookie-cutter" fashion that is, I think, a bit different. It has worked out very well. It's very strong and rigid due the "box girder" structures. (I just posted links as some of the images need to be resized).
                        The 1/2" blue foam sub-bed and risers looking north.
                        http://www.railroad-line.com/UPLOADS...1_134340AA.JPG
                        The same area with roadbed and track in place.
                        http://www.railroad-line.com/UPLOADS...2012-20-02.JPG
                        The trestle on the north end.
                        http://www.railroad-line.com/UPLOADS...r/DSCF0083.JPG
                        (Note: Don't use the white foam. It's bad![!])
                          This is an idea I tried for portable benchwork on a small (32"x66") N scale table-top style layout that I'm building.
                          I built a lightweight open-frame "cart", so to speak, for the layout to sit on when in use, & then lifted off for transport. I built it from some pieces of 1x3, & some old L-girders recycled from a previous layout. (I never throw anything away...just ask my wife! )The structure rides on heavy-duty casters, with locking wheels.
                          Download Attachment: bench1.jpg
                          55.96 KB
                          I inverted the L-girders at the top, so they would lock together with some L-girders that I screwed to the bottom of the plywood trainboard.I use a couple of "Quick-Grip" C-clamps to hold the layout in place, while it's sitting on the benchwork.
                          Download Attachment: bench2.jpg
                          39.67 KB
                          Download Attachment: bench3.jpg
                          56.78 KB
                          -Drew-
                            Hi all
                            Here is a web site of another model railroad that is undergoing reconstruction to increase it's overall size.
                            The site belongs to "Bonkyrail" (Michael Haley).
                            Just click on the link and you can follow the construction that has begun in the new year.
                            The web site also has many other features including the building of the original layout. There are lots of pictures which are a great help in the explanation of the proceedures used.
                            As this is a work in progress you will be able to follow the construction of the new layout from benchwork to running trains.
                            http://www.moctezuma-us.com/bonkyrail/
                              Hi all
                              The following is a topic on building modules that was found at the Layout Construction Yahoo Group.
                              I've built over 50 module sections using foam. Here's what works for me:
                              1) 1"x4" box built to the size desired (my largest are 30"x6')
                              2) 2" foam inserted into the box structure, level with the top of the wood,
                              and secured with Liquid Nails.
                              3) one 1x4 center support under the foam, screwed to the box frame.
                              4) add legs as desired (mine are all off the shelf 1" PVC components).
                              I've never had a module fail with this construction method, which I've used
                              for a 15x28 HO scale home layout and ten (and counting) Ntrak modules, which
                              travel quite a bit.
                              Actually, I've found that inserting the foam into the box frame works quite
                              well to secure the foam, and to protect it. I add a bead of Liquid Nails to
                              the sides of the frame before I add the foam. Adding the foam smears the
                              bead and does a good job in gluing it into place. I also glue the center
                              support, wide end to the foam, to help support the foam. The center support
                              is screwed to the frame.
                              I agree that using plywood ripped into dimensional lumber will be better
                              than using stick lumber for the frames.
                              I've experimented with several leg options, few of which have been really
                              satisfactory. The simplest method is to just screw 2x2's into the corners
                              below the foam, but these aren't removable. I tried 1" PVC legs in sockets
                              screwed to the corners, but this method wasn't really stable. Finally, I
                              came up with something that works well, and which I'm in the process of
                              retrofitting to all my Ntrak modules (and some friends modules as well). I
                              screw 1x4 gussets to the bottom of the box frames at the corners, and attach
                              a 1" diameter floor flange to the gusset. My new legs are 1" PVC with a
                              male adapter on one end, and a plug on the other. The male adapter screws
                              into the floor flange, and is quite stable. I drill and tap the plug for a
                              large carriage bolt, which gives me leveling capability. The only down side
                              to this method is the weight: the four cast iron floor flanges weigh as much
                              as the rest of the module! On the positive side, adding legs to my Ntrak
                              modules is a matter of a couple of seconds.
                              Edit:
                              I think the method that Rusty (Walt) demonstrates on his leg construction would be lighter.
                              Yes, adding the foam inside the frame eliminates the need for other wood
                              supports for the foam. Keeping the frame square during construction is the
                              hardest part of the module building process!
                              I've been having good luck with double sided carpet tape for laying track
                              recently. The jury's still out, but I think it works well. Gasket tape is
                              basically 3M foam tape, which is available at any hardware store. If the
                              carpet tape doesn't hold long term, I'll switch to 3M aircraft tape, which
                              is more expensive, but will NEVER come loose! (did anyone know that many
                              parts in modern aircraft construction are TAPED together?!?). One trick
                              I've found with the double sided tape is that it also holds ballast. I've
                              been ballasting as soon as I lay track, and have basically cut out the mess
                              of gluing ballast! It also gives you the most in-scale ballasting job in N
                              scale I've ever seen!
                              I'm glad all this has been of some use to you! Have fun building!
                              RAY
