BVM mega midget bash
  • BVM mega midget bash
    I started this kit 3 years ago & gave up. Last week it called to me & so now its almost finished. Some window glass & somehow figure out how to install a headlight. Should it be a white 3mm led-not sure how to do it but w/ a little direction from all you folks mayby I'll get done.
    Dale
    Download Attachment: Abby 003.jpg
    121.98 KB
    Download Attachment: Abby 004.jpg
    118.59 KB
    Download Attachment: Abby 001.jpg
    118.26 KB
    Download Attachment: Abby 002.jpg
    116.01 KB
    Dale,
    Glad it called out. Looks pretty cool. the LED you have should be fine. You can always tone it down by spraying the lens with dullcote.
      Hi Dale -
      Nice lil critter ya got there....I will be anxious to see
      how it comes out, as I have one on the shelf too.
      Art knows his stuff with the LED's.....
      He's had a lot of practice!
      The Geezer
        Dale,
        Your critter looks great.
        I have only built the mighty midget, I put DCC in but did not try to light the unit.
        You may consider putting a 1.8 mm LED in for the headlight, most 1.8 mm LED's are less than 15V so you will need a resistor.
        Here is a thread from last year that may help.
        http://www.railroad-line.com/forum/t...TOPIC_ID=22797
          :up:
          Neat Critter!
            Ditto! Cool little loco.
            Russ
              Thanks for the kind words guys. I've been looking on ebay for the correct LED's since I don't have any now. What volt/size/color do you all reccommend? Do I need a resistor for sure & do LED's work both AC/DC? Please understand, I'm not too swift when it comes to electrical thingies...including my puter? :-()
              When I get this wired up the next project might be the BVM shay kit I have, but its a lot more complicated than this little guy.
              Dale
                I may have a little practice, but I think Larry is far more knowledgeable than I am. If he says 1.8 mm then that's probably the way to go.
                  What did you use for the drive unit in this critter Dale?
                  If you don't mind me asking.....
                  The Geezer
                    OK Arthur, I have a lot to learn so many questions will come up.
                    Geezer, I believe it was an old Bachmann 44/70 ton diesel switcher w/ the powered trucks is what I used. Dallas can tell you for sure-they are hard to find but do show up on ebay. It runs quite well, if a bit fast. Some more weight will also help w/ its short wheel base.
                      Dale,
                      I think that Louis (desertdrover) is the real LED expert. I just know the size difference for the 1.8mm LED's I have is helpful on the installs.
                      Here is a link to the thread I did for installing DCC and adding weight to one of these 44 ton power trucks. It really helped the critter run much slower.
                      http://www.railroad-line.com/forum/t...TOPIC_ID=23689
                        Dale, great job on the critter. Thanks for the pictures.
                          Nice little critter, Dale.
                            Hi Dale --
                            Your critter looks great! Nice construction and detailing ... especially like the coloring/weathering effects on the deck and air tanks.
                            Yes, that kit (discontinued) used a power truck from the old 44-tonner with dual motors ... a bit of weight and some break-in time and it should slow down nicely.
                            Dallas
