This is a sticky topic.
  • The last discussion of 3D printing/laser cutting I was present for was in K.C. last year. Summarized, if you do all the design work and prepare the DXF, and all your friend does is load the machine and press the button, I believe it will count as scratchbuilt, points commensurate with the effort that went into the design. But you might not get the Construction/Complexity points a well done assembly of parts would earn.
    • Joe,
      Your question comes up pretty frequently these days, and James is right that as long as you do all the CAD work, all is well. I’ve heard this several times from those in the NMRA who are in the know, like James.
      I think the neatness of the results would outweigh questions of complexity.
      • Well, this is certainly a 'hot button' issue. How do you really measure complexity? If you design a part from scratch on a CAD program, is that more or less complicated than getting a few pieces of Plastruct stock and gluing them in a new shape? Did you have to sit down and think about what the end result should look like? Of course you did. Was there additional skill required? Of course there was. The question should be, as an evaluator, 'what would it take to make this model' and 'could I accomplish this same result.' It's not an easy one size fits all question.
        The difference between a 'simple' model and a 'complex' model is not trivial. Take a look at the point differential in the various categories. https://www.nmra.org/sites/default/f...uide-lines.pdf
        The matrices are very straightforward in how to evaluate a model, complexity is the key, a simple model is very difficult to achieve an 88 score on. Add up the scores. The 'complex' model has the theoretical high score of 125. The best a 'simple' model can attain is 90.
        • Good points, Jim. Being awarded the appropriate number of points requires work both in building the model and doing a good write up. That’s true for any model. If the modeler has any doubt he or she could include the CAD drawings for complex components when doing the write-up.
          • quote:
            Yet you still only need 87.5 points for the merit award.
            My 1st merit award was for a flat car....simple can be "good enough".
            • I would greatly appreciate any guidance on how to build a bolster, such as materials used etc. I've got a pretty detailed CAD drawing for the under frame of a McKean Master Series car, and know what styrene pieces I need to build the stringers and cross members; but the bolster seems right now to be a stumbling point.
              thanks
              Joe in Orlando
              • quote:
                thanks
                Joe in Orlando
                Joe,
                I usually make bolsters from wood with very little detail. However for a contest model I use styrene strip.
                Do you have good drawings for the bolster you want to build?
                The thing with bolsters is that the trucks hide a lot of detail but well-detailed ones will—excuse me for saying this—bolster your bid for points.
                • Pictures and drawings of bolsters can be found in the Car Builder's Cyclopedia. Some, mostly from the pre-welding era, were reprinted in the "Train Shed Cyclopedia" magazines, which you may find at train shows or buy used on-line. There's also an index of Vol. 1-42, but I've never seen it. Publications like these and Railway Prototype Cyclopedia aren't bad investments if you're pursuing contest modeling and/or the Cars AP category.
                  • Joe,
                    Have you had the opportunity to get any of your cars evaluated yet? JBVB's tip on the "Train Shed Cyclopedia" is an excellen choicet. If you find any at Powells.com,or some online used book seller, find an issue with freight cars, they are pretty specific, and you don't want to spend money on a Steam Locomotive. yet!
                    PS Check your local library.
                    • Guys,
                      Thanks for the replies to my bolster inquiry.
                      Mike- did you just CA some styrene strips together and then sand away to create your contest model bolsters? Did these contest model bolster have tapered sides or just tapered tops?
                      jbvb - I looked at Powells.com and all the Train Shed Cyclopedias are "out of stock"
                      Jim - I have completed one car so far but I have not had it evaluated yet. My judges come from the Tampa, FL area and my plan is to have three cars (plus my Civil certificate work which I finished in spring 2018) completed before I ask them to make the trip over.
                      Joe in Orlando
                      • Joe,
                        There are a couple of ways to get the taper. As you suggested, you can glue up several strips to the thickness you need and then use a file to make the taper. I've done this more than once with end sills on pre-1900 boxcar and caboose models. For the caboose I had to taper in two directions.
                        The other approach is do do something like I did on this unfinished model:
                        In this case, the bolster is an early one made of several iron or steel parts; for a twentieth century bolster I would glue rectangular pieces of styrene to each side and cut off the excess. I think one would get a more accurate taper this way. It might not be any more work. It could be done in two directions.
                        By the way, I use a styrene solvent cement for styrene, not CA. It really welds things together.
                        • Drover caboose inquiry
                          I am intrigued with scratch building a Drover's caboose as on of my 8 cars. If anybody has any good dimensioned drawings for a Drover caboose I'd greatly appreciate it if you would send them to me at Joebrann@AOL.com Subject = Drover. Also if anybody has any good photos of the interior of a Drovers caboose that they built I'd appreciate seeing those also. Is scratchuilding a Drovers caboose a frequent way of completing the "passenger" car requirement of the Car Certificate.
                          thanks
                          Joe in Orlando
                          • quote:
                            Here are 2 that I scratchbuilt:
                            I gave the larger one away......
                            Usable for Passenger car requirement - yes. In fact, I think the smaller one won Passenger Car a few years back at a regional convention.
                            Plans? I build these 2 w/o any plans and just adopted picture (Cotton Belt prototype???). I rarely worry about plans getting in the way of my building whatever it is that I feel like building. Got Merit awards on 3/4 of my entries in this year's regional convention contest room.
                            • Beautiful work on your Drover cabooses. Your comment that you built the cars "w/o any plans and just adopted picture". Does that mean that you took some measurements from the photo and made you own good judgments wrt length and height of the car and size of the windows, etc? I had the very god fortune of having a wonderfully detailed article to follow when I did my first car, and I'm afraid that may have jaded my thought into thinking that I need to find the equivalent in order to start my next car. I've already lost possibly 4 months in attempting to extract consistent dimensions from a set of Mather stock cars. That activity is currently on hold. And yes I do know that the Mather Manufacturing company was not overly consistent in using the same sizes and materials across their car line.
                              Joe in Orlando
                              • quote:
                                Thanks!
                                No. Much more basic dimensional measurement to start with - width of the floor based upon the body bolster for the trucks. Built the floors first and that defines the width of the car everywhere; castings for steps set out the platform size requirements. Basic windows and doors set the height measurement and then effectively also the length of the car. Thickness of sides and ends set the rest of the dimensions.
                                Several years ago I wrote a column for O Scale Trains describing scratchbuilding a trolley car end w/o measuring anything through the entire process using just 1 window casting as the reference point for all dimensions.
                                Now I would have thought that info might have been published in at least 1 magazine somewhere, some time.
