This is a sticky topic.
  • I've used both plastic and brass castings from Cal-Scale. The plastic hoses are easier to fasten to a styrene carbody, but also easier to break.
    • I very rarely use any air hose castings other than those from Precision Scale (Kemtron) and always in brass.
      • I'm wondering if anybody has had their cars Merit Judged lately and if so have the Merit Award Judges been lenient at all wrt the size of the brass wire used for the piping etc. of the brake system. There seems to be an absolute dirth of 0.015" and 0.022" brass wire these days. I do ave a good supply of 0.012" and some 0.019" brass wire which it looks like I'm going to have to use. Does anybody see any problem with using the 0.012" and 0.019" wire w/o being penalized?
        thanks
        Joe
        • Unless you're grossly out of scale, I doubt that there's a problem - they are not going to have a micrometer handy. It's by eye and by golly that looks about right. That you have it at all and it's in correct or at least plausible locations connected reasonably correct should be adequate.
          I honestly never worried about using a size other than "that's looking ok".
          • What Martin said. :up:
            • I didn't buy any, but I saw that Tichy brought a full rack of their phosphor bronze modeling wire to the Amherst Club show last month. They sell both pieces about 6" and pieces about 36", though the latter will be inefficient to ship safely.
              • Joe,
                I think if you checked other modelers and the better kits you’d find variability in wire sizes used for brake rigging. For instance, the Tichy box car kit uses 0.010 wire for brake rods and 0.020 for train line and brake staff.
                • Grab Iron Standoff
                  I've found some pretty good information wrt the width of grab irons; but I haven't seen any information wrt the standoff distance of the grab iron from the side of a car. Any help would be appreciated.
                  Joe
                  • I think both width and stand off distance is pretty variable and if you use the pre-formed wire or brass castings for grabs that set both of these dimensions that no one will ever argue on this dimension.
                    • When gluing grabs in place I usually slip a scale 2” piece of styrene under the grab. The resulting standoff looks right to me.
                      • AB Brake kits
                        I'm installing my first Cal-Scale AB Brake system and need some hole. I bought the brass version of Cal-Scale brake system and am trouble drilling holes to more securely hold the various size wires I plan on using for the piping. Has anybody had success with drilling into the brass pieces of the Ca-Scale set; OR have people generally used the Cal-Scale plastic AB brake system kit?
                        thanks
                        Joe
                        • Joe,
                          Drilling into a brass casting is difficult, especially for the diameter carbide drill you would use. Brass is much harder than aluminum or 'pot metal'. Use the plastic, once it's painted nobody knows or measures a Rockwell number.
                          • quote:
                            If you're using a pin vise to drill brass, you're going to be there close to forever and will probably end up breaking a few drill bits, too. If you have a small drill press, this gets a lot easier a lot faster.
                            If you have the option of plastic castings that are good, go there. If they look right, then they are right.
                            • I've drilled quite a few #78 and finer holes in brass and plated brass passenger car sides without a lot of difficulty. Patience, a quality HSS drill & pin vise, maybe a tiny bit of oil for lube. It won't go fast.
                              • Thank you for your inputs on using plastic AB brake kits instead of the Cal-Scale brass kits. I've just returned two brass kits to Walthers and will be ordering 4 more plastic ones to go along with the plastic kits I bought along with two brass kits some time last year. If anybody would like the two brass kits I have I'll be glad to mail them to you. One of the reservoirs has one or two #78 holes drilled into it.
                                Question: When the main brake line crosses from one side of the under frame thru/under the center sill is the angle that the brake line subtends a standard angle such as 45-degrees? IS the angle subtended a "detail" point that the judges look for?
                                thanks
                                Joe
