I bought one of the Extenders; plastic dual RJ-45 jack and 10 feet of flat cable. But I want a longer run to the next jack (I'll mostly be using my Prodigy Wireless), and I'll also need a few more connections right at the base station (control buses going both ways, a radio dongle and room to plug a throttle cable in too).
I've got an RJ-45 crimper and connectors; has anyone got experience using Cat-5 cable for an MRC throttle control bus? If so, do you use the standard pinout, or something special (I can ring the cable out with a VOM if necessary, but it's a lot like work).
I Googled up one reference to a module group that uses Cat 5, but they also say that after 5 modules you need a "control bus booster", which I guess I need to find out more about. I can get away with 5 or fewer sockets on my layout, but it would be nice if I could use a total control bus cable length of around 60 - 70 feet.
