I've been busy relaying the old Atlas code 100 to handlaid code 83 and code 70 rail and building my turnouts using the free templates made available from "Fast Tracks". (thanks Fast Tracks!)
Here are a couple of shots of some rough cut ties I'm using on my logging branch.
As you can see, I'm using regular ties in order to set the gauge and then I'll attempt to spike the roughcut ties with my tiny spikes.
I'm using dried "Lantana" plants, as they have woody stems.
Here's a close up of a single tie that has been sanded down even with the regular wood ties.
Finally, here is a shot of my turnout control....the caboose industries seem to route power through the points for present...I will be install contacts for routing power to the frog.....tom
