Little Giant Conversion
  • Little Giant Conversion
    Ooops, the donor loco photo got lost, try this ....
    Download Attachment: Hornby-Donor.jpg
    60.14 KB
      Nice, do you plan on making it a tank locomotive or are you going to add a tender?
        Now here's the quandary......
        Over in the lounge, I raised the problem with the boiler and how it had forced a change of plans.
        I'm still undecided as to whether to convert it to a 0-4-2 side tank with a fuel bunker - that would mean a new deck; or keep it as 0-4-0 side tank with a small tender for the fuel - the excuse being that the cab was a modification for the comfort of the crews, but it meant the loss of the original fuel bunker.
        Decisions, decisions!
          only down side is the scale 500mph speed you get out of the chassis, but once on dcc they calm down abit
            David,
            I just started to look at your project. Nice work and effort, I think you are heading dow the right road. I would, if I were wacking and hacking put side square water tanks, with piping and fills, and a fuel bunker on that back. The side tanks will resolve a whole host of problems, design wise. I also when I was doing my 2662T conversions, I used the porter cab. I might suggest you lower this cab a bit to break up that line, and it will add interest, if you have room to do it. Just a thought.
            Les
            Baron of Junk...Railbaron #15
              David,
              Interesting project ... looking fwd to see where this one goes
              Tom M.
                David,
                Interesting project I will be watching closely.
                I have a question did you turn down the wheel flanges or are the newer Hornby flanges smaller?
                  hornby have smaller wheel flanges now (thank god)
                  IMO if i did something like this i would have gone with the ex dapol pug chassis
                    What is an "ex dapol pug chassis "?
                    Tom M.
                      http://www.modelfair.com/acatalog/da100115.jpg
                      much smaller then the hornby 0-4-0 and ive got mine running very slowly if needs be
                        Nice little loco .... are they still available?
                        Tom M.
                          yup, now under hornby
                            Big Lars,
                            Did nothing to the flanges - all my track is Code 100, so not a real problem anyway.
                            Andykins, I have already done one bash using a pug and another on a Smokey Joe.
                            This time I wanted something a bit bigger.
                            made some more progress as seen in the shots below.
                            Decided it definitely needed a bunker, so the original cab had to go.
                            So a new deck, find the un-bashed Forney cab ( I'll look for the doors when we get back from Dublin).
                            Chopped up a brand new EDM tender and went a bit wild with the B & D - hence the repair job!
                            Looked out a spare pony truck from some Bachmann Loco and tacked that on.
                            Side tanks are only formers at the present.
                            God, the Internet is slow tonight!
                            Download Attachment: DSC_2359_web.jpg
                            77.54 KB
                            Download Attachment: DSC_2360_web.jpg
                            91.16 KB
                            Download Attachment: DSC_2361_web.jpg
                            87.51 KB
                              Hmmm, this thing is getting to be like Topsy :erm:
                              Took a break while we went to Dublin for a long weekend and when I got back last night, it occured to me that the pilot deck was on the small side. So I extended it; so far so good, but a second look showed too much open space in front of the cylinders now[:-irked], a quick trawl through the bachmann green boxes provided a leading truck and now it is a 2-4-2 [:-slaphappy]
