Hey everyone,
Here is an idea that I have for a small track plan. The concept is that the front is a lower level with the loop going uphill to the switchback in the rear. A slight uphill grade to the right again gets to the mine tipple.
As for the lower level. The left side is for the engine house (Porter 0-4-2). I don't have water in there yet but it will be there also. The track on the front left is a run around with a tail track in the far left front. On the right front is the interchange with the other part of the world. It will be a 3' gondola for carrying the ore off to buyers. It says standard gauge on the plan but I had other thoughts last night. To the right of this is a small river.
As you go to the right side past the interchange you start upgrade. We rode the Durango and Silverton this year so I picture this as a short segment that is based on the "high line" of the D&S. To get this I will have a steep topography on the inside of the curve that helps as a view block. Grade will be 3.3% or less through the curve giving me about 2" elevation when I get to the back of the layout.
On the backside, most of the switchback will be hidden behind a tree line and, if there is room, some small rock outcroppings that rise above the surrounding terrain. Up the slight hill to the ore tipple and we are finished until the loading is accomplished.
Loco is a Porter 0-4-2 with scratch built ore cars of about 16'. I will also build a small boxcar to haul supplies and maybe a combine for miners in the morning and evening.
The overall size is 30" by 80". It will be built on a hollow door with a layer of foam to allow for below grade scenery on the lower section.
This is just a simple draft of ideas I created on an airline. I used Photoshop for the painting so it isn't nearly as detailed as the CAD guys. Any comments or suggestions would be appreciated.
James Nichols
James Nichols
