The Sn3 Branch
This is a sticky topic.
  • One of the upright grab pole popped out when I was doing work on the frame and I couldn't find it. [!] I didn't like the way they looked anyway, although it was prototypical for 'un-bashed' Davenports, soooooo I decided to put a protective railing on each side supported by a flatbar stanchion in the center. [:-bulb] Here's the upright grab pole before it disappeared:
    I took flat bar brass stock and notched out part of one end to form a pin to insert into a hole drilled into the frame deck and a hole drilled near the top of the stanchion for the railing to pass through. Another deck hole was drilled forward near the stirrups for the vertical end of the railing to fit into. I drilled a corresponding hole on the cab to receive the other end of the railing. The railing terminates on the deck and at the cab into 'fittings', small plastic hollow pieces used for joing brake system air piping. Here's the the first completed railing:
    I'll put on a railing on the other side along with the last stirrup tomorrow.
    • I like the railing better than the pole - looks good.
      • Russ,
        Both your railings and your steps are big improvements IMHO. Nice work.
        • Thanks, Guys...Here's a Davenport GM30 side-rod critter with the stirrup steps and side railings. Looks like some typical post-delivery 'modifications'. Units like these are where I get my ideas from and then fit them to my own locomotive's 'style' that I'm trying to define.
          http://www.northeast.railfan.net/images/mpcx8.jpg
          • That looks really good Russ. Nice to see an Sn3 model that isn't DRGW
            • Nice work on the railing Russ, looks way better than the pole! :up:
              • quote:
                Hello, Neil...
                Thanks for your kind words. Sn3 models other than the Colorado prototypes are very under represented by manufacturers. My railroad is centered in New York State and I want it to have my own 'look' as much as possible. I can't see the point in buying Colorado prototype models and then claiming they are in an Eastern US setting! [:-paperbag] Sn3 has suffered from lack of variety which has led to its own stagnation. I sent an email to the major brass Sn3 manufacturer asking if they had plans to do models other than D&RGW/SP. They responded that there was no interest. [!] Of course there wasn't...they only survey their own customers and admirers on the Yahoo Sn3 board! If a major player like Bachmann began producing in Sn3 with generic models of interest, it would be a new ballgame. In the meantime, keep those scratch building tools and materials handy!
                • I think you are right. Sn3 manufacturers rather shot themselves in the foot with the lack of variety and then On30 came along with more variety and at a lower price. There's no reason it shouldn't have been Sn3 instead but it didn't work out that way
                  • quote:
                    S scale is strange. It has no appeal. If you say you model in S scale you might as well have two heads.
                    It only appeals to a certain group. A person is either an S scale person or not. There are no converts. I have had more enthusiasm for my Scale55 than anything I have posted about S scale.
                    Bachmann would have taken a bath with S narrow gauge on HO track.
                    S scale will die out with the boomers in the US and I have been a big proponent since the seventies. It has withered greatly.
                    Go figure
                    Harold
                    • I don't quite understand why S scale has such low appeal. It's more compact that O scale and allows more detailing than HO so it sounds like a winner on paper but it falls between two stools and isn't popular with O scalers who want more space or HO scalers who want more detail.
                      1:55 looks great because it is between O and HO and there is pseudo-HO and On30 equipment that you have demonstrated can be kitbashed into convincing 1:55 models but unfortunately S scale does not have that advantage. As Russ says, it all has to be built from scratch
                      • Harold (hminky) is the 1:55 champ with a skill for creating properly scaled models from existing production stock. I had to decide if I wanted to model a switching shelf layout in HO based on the Erie RR, a traction shelf layout in HO based on my own Hudson Electric, or Sn3 based on my own Catskill & Ramapo. When I decided on Sn3, it was because of the larger-then-HO but smaller-than-O scale rationale. I liked the scale for detailing and the fact that I could get about the same amount of action on a layout as with HO. I also knew of the limitations as well concerning lack of variety in the models, so I keep my xacto blades well sharpened. Because I'm building a small layout, there's enough structure kits, rolling stock, etc. out there for me, but motive power is always an issue when not modeling Colorado prototypes. The Davenport diesel that I'm working on is an affordable way to get a loco up and operating, but steam is going to be another story. I'll probably get one of the PFM Sn3 Colorado & Southern locos (#14) that doesn't have the air tanks mounted on the boiler. It would have to be changed a bit to 'de-Coloradoize' it, get it re-powered (another 200.00), and then paint and letter it for my C&R. This Overland model from Caboose Hobbies would also make a prime candidate for 'Easternizing':
                        http://www.caboosehobbies.com/catalo..._image_ext=jpg
                        In the meantime, I'll be working on my Davenport!
                        Russ
                        • Now yer cookin Russ!
                          I have a soft spot for bashing d-cells.....
                          this one looks great!!!
                          • I put together the other side railing for the fireman's side of the switcher today. I also had the urge to take off the sun shades. They did add balance to the look of the cab, but without them they look more 'Davenport'. Arrrg! What to do! [:-shake] Well, I decided to take em' off and leave em' off. It creates more body 'n fender work for me, but I just added it to the list of filing, filling, and sanding that I have to do before priming. [:-paperbag] I think it makes the cab look more 'prototypical'. Ya think?
                            Russ
                            • Russ that Davenport picture you referenced at http://www.northeast.railfan.net/images/mpcx8.jpg looks like it has a canvas sunshade folded up on top of the cab. You might try that.
                              • quote:
                                Now THAT'S an idea...yeah...use the existing holes for the support poles...maybe make it so it's open maybe not so far? Use glue-stiffened tissue painted a greyish-tan? Hmmmm....[:-idea]
