Issac's Iron Works (Bar Mills' Jerry's Small Engine Repair)
  • Issac's Iron Works (Bar Mills' Jerry's Small Engine Repair)
    Time's a wasting. Now that October has arrived, I realized that our 5th Great Grandchild will be born later this month and I've only built one structure in the "Great Grandchild Series" That was for Aubrey, the oldest. Here is Aubrey's Apparel (a repurposed 70 year old kit from Summit Engineering):
Name:	Aubreys Apparel 1f.jpg
    The next oldest of the youngsters is Aubrey's Brother Issac. The business bearing his name will be Issac's Iron Works. Our youngest son gave me the Bar Mills' "Jerry's Small Engine Repair" kit last Christmas, so I will use that as the basis for the build.
    Here is what the box looks like.
Name:	Jerrys Small Engine Repair Bar Mills 1f.jpg
      I'll be following Bruce.
      Curt Webb
      Freelanced PRR Bellevue Sub
        Looking forward to this Bruce. Bar Mills do great looking designs for their structures.
        Melbourne, Australia
        Borrow money from pessimists – they don't expect it back
          Looks like a fine project. Bar Mills kits are great bones to modify and adapt.
          KarlS-Curmudgeon
            Looking forward to the build Bruce.
              Thanks for checking in Curt, Rob, Karl and Jerry. Here are some shots of the structure from various angles taken from the instruction sheets.
Name:	Jerrys Small Engine Repair Bar Mills 2f.jpg
              Rear View:
Name:	Jerrys Small Engine Repair Bar Mills 3f.jpg
              Side view:
Name:	Jerrys Small Engine Repair Bar Mills 4f.jpg
              Top view:
Name:	Jerrys Small Engine Repair Bar Mills 5f.jpg
                That looks like an enjoyable project. It'll be interesting to see what you do with the kit.
                Before each flight, make sure that your bladder is empty and
                your fuel tanks are full.
                  Bruce,
                  Looks like a fun project. The Bar Mills kits always look good. I assume you will deviate from the instructions?
                  I was so much older then, I'm younger than that now Bob Dylan
                    Bruce, I've always liked the Bar Mills kits.
                    Have fun building it.
                    FaceBook link: https://www.facebook.com/A-Dog-A-Van-and-A-View-108345371976229 YouTube: https://www.youtube.com/@RickS727
                      Thanks for checking in George, Mike and Rick. I will probably stick quite closely to the kit instructions except for the signs and roofing materials.
                      I've done some initial painting. Rattle can of light grey primer then an over coat of a pecan brown from another rattle can. On the walls of the main structure, I've left some of the grey show through. A darker brown for the trim.
Name:	Wall Sheet Painted 1f.jpg
                      I love the fact that they laser cut the rafter tails!
                      Here is the other parts of the kit.
Name:	Doors and Trim 1f.jpg
                      And finally the detail castings that came with the kit - I haven't started cleaning them up yet.
Name:	Detail Castings.jpg
                        Great start Bruce. The walls look like they are very thin. I've never built a Bar Mills kit.
                        Curt Webb
                        • Dutchman
                          Dutchman commented
                          Editing a comment
                          Curt, they are 1/16" thick, but small enough that they won't need much (if any) bracing.
                        Time to break out the glue.
Name:	Sides ready 1f.jpg
Name:	Door Window and trim 1f.jpg
                          Making great progress Bruce.
                          Curt Webb
                            That's a neat shaped structure that draws the eye
