A Second King Post Bridge Build (20 Year Celebratin Challenge)
  • A Second King Post Bridge Build (20 Year Celebratin Challenge)
    Way back in 2006, I did a build thread on a King Post Bridge. Here is the link to that thread: https://railroad-line.com/node/2227.
    In that thread I included a link to plans for the bridge that I found on the Tennessee Dept. of Transportation web site. Sadly that set of plans no longer shows up.
    I now need a King Post Bridge two feet longer and two feet wider than the last bridge.
    So, here we go.
    With the older bridge in the background, here are the plans for the new bridge. The first bridge was designed for vehicular traffic, and so had deck planking. The new bridge will be for the railroad, and will only have RR ties on the deck. (The first bridge was built to fit against the backdrop, so I had no room for the diagonal brace on the truss.)
    Click image for larger version  Name:	Plans 1f.jpg Views:	0 Size:	94.4 KB ID:	1031481
      Looking forward to this build.
      • Dutchman
        Dutchman commented
        Editing a comment
        Thanks for checking in, Jerry. This should be a very quick build.
      Since you're building a new bridge... One thing that bothered me about the previous bridge is that I thought it was a bit too long, that the ends of the bridge sat too far back on the rock. That's something to consider as you work out the new bridge. The other thing would be to consider if you need heavier timbers for the railroad.
      • Dutchman
        Dutchman commented
        Editing a comment
        Dave, I had widened the gorge a bit - in fact a bit too much. This bridge will have its end timbers just sitting hear the edge of the gorge. I did 'up the dimensions of the timbers a bit, too - and added three joists that will sit just under the rails as was the cast in the Hunter Line Queen Post Bridge.
      • deemery
        deemery commented
        Editing a comment
        Sounds good!!
      Bruce,
      Re-using the old king truss was a noble effort, but it looks like a new one will reign supreme.
      • Dutchman
        Dutchman commented
        Editing a comment
        Mike, an HO loco almost touched the railings on both sides of the old bridge. I will still use it, most likely on the upper HOn3 Slate Run RR.
      Nice build to follow Bruce. Looking forward to your progress here.
      [Edit] Bruce, I just checked my files and found this from your old build. Is this the plans???
      That was back in the day when I was only a lurker. I liked your build so much I kept it on file.
      Click image for larger version  Name:	King Truss Bridge.jpg Views:	0 Size:	206.4 KB ID:	1031513
        Lou, that is indeed the plans from Tennessee. Many, many thanks.
          OK, if that was it than here is the PDF.
          King Truss Bridge.pdf
          • Dutchman
            Dutchman commented
            Editing a comment
            Thanks again, Lou1
          Looking forward to this Bruce. Nice looking bridge.
          Thanks for the PDF Louis, we can always rely on you.
          Karl. A
          • Dutchman
            Dutchman commented
            Editing a comment
            There is a certain 'cute factor' at play with a little King Post Bridge, Karl.
          Short build or not, I always like a good bridge.
          And thanks to Lou's library- i downloaded that PDF for my files... Just because
          • Dutchman
            Dutchman commented
            Editing a comment
            Thanks, Carl. Bridges are always good for 'photo ops' and I intend to have more of them on the new layout. (The old layout had 3.)
          I'm watching.
          • Dutchman
            Dutchman commented
            Editing a comment
            Thanks, Rick.
          If I’m not mistaken there can only be one King in a domain…you’re going to have to demote the smaller one… pretender to the throne…
          Interesting project that should be a fun build.
          • Dutchman
            Dutchman commented
            Editing a comment
            Karl, I could call the smaller bridge the Prince Harry Bridge.
          • k9wrangler
            k9wrangler commented
            Editing a comment
            That’s a great idea…Megan the troll….
          • deemery
            deemery commented
            Editing a comment
            Ah, "The Harry formerly known as Prince" ....
          All the wood needed for the build is cut and in the A&I mix. I added 'wood grain' before cutting.
Name:	Staining Wood 1f.jpg
          I always lay the wet wood on a piece of waxed paper so that the 'juice' is not wicked away from the wood while drying.
Name:	Wood on Waxed Paper 1f.jpg
            Bruce,
            Very nice start and I'll be following along.
            Tom
            The difference between the almost right word and the right is the difference between the lightning bug and the lightning.
              I'm following along too. I'm sure after building the first bridge, this one will be an easier build.
              • Dutchman
                Dutchman commented
                Editing a comment
                For sure, George. It is nice having the old one to check measurements and see how I glued certain timbers in place back then.
              • Dutchman
                Dutchman commented
                Editing a comment
                It is handy having the old bridge on hand to check timber dimensions and to remind myself how I glued certain timbers in place back then.
