We've been in our house for 22 years now. As I was doing projects on the house, I would need to get lumber for certain projects. Well, every time I went and got wood for the house projects some lumber followed me home for the layout to be. I started with a sheet of 4 X 8 3/4" plywood, a sheet of 4 X 8 1/2" Homasote and many board feet of clear pine for an L girder subbase. That got put in the corner of the basement approximately fifteen years ago. Today I needed some wood to build a couple of drawers for the kitchen cabinet. I found four 12" X 3/4" X 8' clear pine layout on the old layout under many other layers of assorted material. The layout wound up as a horizontal storage space. So I had to get everything off to get at those boards. While doing that I thought I could use this as part of the limestone quarry layout. So I cleaned it off to the point where I had place a sheet of plastic over it to protect it. Glad I did, the mice had a field day. Unbelievable that they carried sunflower seeds from the garage all the way back to the other side of the house. But I digress.
Here's a picture of tabletop with everything cleared off.
As you can see, they made a mess on the tabletop.
Once took the plastic cover off I discovered my missing HO/O scale Ax-acto ruler, a couple of NS track sections and on Shinohara #6 turnout, plus several survey maps of Rochester Junction of the Lehigh Valle RR. and some cork roadbed.
I had taken the original map and ran it through a copier to enlarge it. I've got all the survey maps from Rochester Jct to Rochester yard, An old friend of mine and I found the original survey maps at a train show many years ago. I had planned on building LV's Rochester Junction when in the house. As you can see it never materialized. So, I disassembled it to move it where it will be part of the quarry railroad.
And if folded up like an accordion when taken apart.
And unfolded.
All back together again. Note to self: next time mark the legs to where they are attached, Yup, I had them on swapped around. The layout will have a final resting place on the other side of the steel column once I get that bench and headboard move out of the way. I probably should have put this in my other thread on Basement Redo.
The layout is quite a bit taller than the site of the rock crusher. That's why it needs to go on the other side of the column so that there will be a gentle grade to get up to that level. There will be more to come. I'm going to do more rearrangement tomorrow. I'll continue this in "The New York, Vermont & northern Rwy. thread here: https://railroad-line.com/node/39637/page25
That's it for tonight. See you tomorrow.
Merry Christmas to all of you.
And unfolded.
