Repairing and Repainting a Southern MS-4 2-8-2
  • #16
    If you'll look again at the photo below, you'll notice there is no smoke or wind deflector on the top rear of the cab.
    This was a challenging repair. I cut and filed a piece of brass to fit the length of the missing part and also shaped it to fit the cab roof angle. It was then soldered in place using the micro mini torch. You'll also note the cab roof has been polished/buffed. This makes it much easier to solder the two parts together.
Name:	New Smoke Deflector Made.JPG
Name:	New Smoke Deflector Soldered.JPG
    Done for today.
    • #17
      Having done much soldering myself I have to commend you on your technique for that smoke deflector. Nice job.
      • #18
        Excellent work
        • #19
          Thank you for the kind compliment on the smoke deflector. It was challenging for sure.
          Tom
          • #20
            Originally posted by k9wrangler View Post
            Excellent work
            Karl,
            I appreciate the compliment and comment on the soldering.
            Tom
            • #21
              The Elesco Feedwater Heater was loose and the pipes on each side were unsoldered. The Elesco FWH had to be reseated on top of the smoke box and then resoldered. The pipes were then also solder to the FWH.
              Click image for larger version  Name:	Right Elesco Pipe Fixed.JPG Views:	0 Size:	64.2 KB ID:	1010541
              Click image for larger versionName:	Left Elesco Pipe Fixed.JPGViews:	0Size:	65.1 KBID:	1010542
              • #22
                The front board between the two smoke box supports had to be resoldered as well.
                Continued -
                • #23
                  The drain condensation and water suction pipes on both side were unsoldered and off the loco. These were straightened and resoldeered in place. Both sides shown below.
Name:	Repaired Right Pipes.JPG
ID:	1010548 Click image for larger version
Name:	Repaired Left Blowdown Pipes.JPG
                  Done for now. More photos tomorrow afternoon.
                  • #24
                    Thanks for posting all the photos. I can't get enough of this type of work. So neat !
                    GULF COAST & WESTERN
                    • #25
                      John,
                      Happy to see you are enjoying the photos. I'll have more this afternoon,
                      Tom
                      • #26
                        When PFM imported this model of the Southern MS-4 Mikado, an instruction sheet came with a suggestion for backhead detailing. Of course, the buyer had to purchase the parts. The parts were all available from Cal-Scale, HO scale super detailing parts.
                        The extra parts were stuff like Air Brake Stand, Front End Throttle, Horizontal Throttle, Reverse Quadrant, Gage Assortment. In addition to the cost of the loco the buyer, If he/she wanted backhead detail, would spend another $30.00 in brass detail castings.
                        The next photo shows what I had on hand and added to the backhead.
Name:	Eight New Backhead Details Added.JPG
                        Everything was the disassembled and ready for paint.
Name:	SRR4867 stripped.JPG
                        More in a few.
                        • #27
                          The loco was again dipped in warm water to wash off any finger grease or oils and then baked dry in the over at 145 degrees for about an hour.
                          The loco parts were removed from the oven and when dry the spray painting of the loco began.
                          So, I'll fast forward here and show you the painted loco starting with the cab interior. You can see that I also added the rest of the detail parts prior to painting. The cab was painted with a mix I made using Scalecoat Southern Green and White. Gauge faces were painted white and the valves were painted using Floquil Signal Red.
                          I used a napkin wrapped around a toothpick for the cab curtain. I tied the ends with thread and then painted it using Floqui Mud color. The toothpick was then removed. Acetate was cut to shape and added to the inside of the window frame. Throttle bars and handles were painted with Floquil Brass.
                          I'll also add here the loco was painted in stages and each stage was baked in the oven at 145 degrees for the hour.
                          I'll show the rest of the loco later this weekend.
                          • #28
                            Nice paint job. Love all those little cab details on a steamer.
                            • #29
                              Thank you, much appreciate the comment. The cab details on a steamer are nice especially if you can see them.
                              Tom
                              • #30
                                Hey Tom just getting around to this thread. A most excellent job!!
