I have lots of styrene strips, angles, rods, and tubes of many sizes, mostly from Evergreen Scale Models plus a few from Plastruct. Until now I've just been shoving them into whatever nook or cranny I could find in the piles of stuff surrounding my modeling work area. I have long planned to devise a better storage solution, but lacked a "round tuit".
Well, recently I finally got around to it! I built it out of 3mm thick Sintra PVC board. I started by constructing segments, as seen here:
The segments were designed to fit together in a stair-step manner, with each segment being 2" higher than the previous segment:
About halfway through I realized this spacing was going to make the rack too tall. So the the spacing of the remaining four segments was reduced to 1.25". When all eight segments were glued together, I added sides made from 3mm Sintra, and a bottom made from 6mm Sintra. I also added a handle to make moving or carrying the rack more convenient:
When complete, I filled the rack with the styrene materials:
Then I realized I could make it even more useful by adding a couple pockets at each end. These will hold sheets of plain styrene on one end, and specialty sheets such as scribed siding on the other end. Two smaller pockets can be used to hold additional strips, tubes, etc in styrene or brass:
I'm still trying to decide what to store in the rear of the rack. Can't let all that empty space go to waste!
