Railroad Line Forums - Xn-view software
[ Active Members: 3 | Anonymous Members: 0 | Guests: 298 ]  [ Total: 301 ]  [ Newest Member: Opa George ]
 Xn-view software
Author Previous Topic: Bar Mills HO Cundy Harbor Dock House Topic Next Topic: Emporium Seafood Co.
DSERR
Posted - 07/26/2019 :  5:50:44 PM  Show Profile  Reply with Quote
Looking for suggestion re software for reducing size of photo images. That is the size of scale as printed, not size in terms of bytes or quality. I use xn-view for the latter. Does it also have a tool to reduce physical size/dimensions.
Thanks
Jim is
Country: USA | Posts: 20
DSERR
Posted - 07/26/2019 :  5:57:56 PM  Show Profile  Reply with Quote
Intended to post sticy Signs for structures. While a long term member not an active poster to date. Sorry
Country: USA | Posts: 20 Go to Top of Page
Posted - 07/26/2019 :  7:50:35 PM  Show Profile  Reply with Quote
I use Open Office as my word prepossessing software, but I'm sure Microsoft Office can do the same thing. Paste the picture to an Open Office document, right click on the picture and select “Picture”. You can then set the dimensions in inches, keeping the horizontal and vertical ratio. You can copy/paste that to what you are working on.
Country: USA | Posts: 15964 Go to Top of Page
railmus
Posted - 07/26/2019 :  9:45:34 PM  Show Profile  Visit railmus's Homepage  Reply with Quote
I suggest Irfanview! Free download and you can do a lot with it! Well worth the look.
Even NASA uses it!
Country: Canada | Posts: 2003 Go to Top of Page
DSERR
Posted - 07/27/2019 :  05:50:13 AM  Show Profile  Reply with Quote
Thanks for the responses. As an old timer I use Word 2003 and cut paste and resize is more complex, at least for the time being. Need to experiment. Will try Irfanview later on when get to office and PC. Your input is appreciated.
sgtbob
Posted - 07/27/2019 :  07:02:12 AM  Show Profile  Reply with Quote
I use paint.net, another free download.
Country: USA | Posts: 4016 Go to Top of Page
Posted - 07/27/2019 :  07:19:32 AM  Show Profile  Reply with Quote
Image size is one thing but the image quality (resolution) is important as well.
You can leave your pictures larger if you reduce the resolution to get the file size under 200kb.
Country: USA | Posts: 23642 Go to Top of Page
Posted - 07/27/2019 :  08:52:07 AM  Show Profile  Reply with Quote
If you're on a Mac, Graphic Converter is one of the greatest apps ever. I've been using it for close to -30 years- (which says something about any product that's been around that long.) It does a lot of what Photoshop does, but it's a lot easier to use and a lot cheaper. https://www.lemkesoft.de/en/products/graphicconverter Support is pretty good, a couple of times I've had questions or problems and gotten a response from the developer within a day.
Country: USA | Posts: 8357 Go to Top of Page
bitlerisvj
Posted - 07/27/2019 :  11:26:06 AM  Show Profile  Reply with Quote
I use XnView to size images when I want to post them here or any other site. There is no problem in doing that. Check the page at http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=24682
Regards, Vic B.
Originally posted by DSERR
Country: USA | Posts: 1442 Go to Top of Page
Posted - 07/27/2019 :  11:36:48 AM  Show Profile  Reply with Quote
If this is what I think you are asking, then once you open a picture in XnView, you can go to "Image", then click on "Resize" and work with your picture size.
Country: USA | Posts: 15780 Go to Top of Page
JimF
Posted - 07/27/2019 :  7:20:08 PM  Show Profile  Reply with Quote
There is also Gimp, which is totally free software, and available for Windows, Mac and Unix
Jim F
Country: USA | Posts: 203 Go to Top of Page
BurleyJim
Posted - 07/27/2019 :  11:35:29 PM  Show Profile  Reply with Quote
Rick makes an excellent point. For looking at the photo 'online', the resolution of your screen is no better than 72dpi (pixels) so any digital photo with a resolution greater than 72 dpi is sending the excess straight into the bit bucket. You'll never display them. Printing is a different story though. You might want to save the dumbed down version to a different folder without deleting the high resolution printable original.
Country: USA | Posts: 5372 Go to Top of Page
DSERR
Posted - 07/28/2019 :  05:57:46 AM  Show Profile  Reply with Quote
Everyone, thanks for all the input and suggestions. The easiest method found is Irfanview. Still cannot get Xn-view to cooperate. My version is different and the resize screen is more complex. Anyway thanks to you folks my problem is solved. Also going to try using an older Adobe product called Photo Deluxe.
Steam was generated in 0.83 seconds. Powered By: Snitz Forums 2000
