Railroad Line Forums - Rebuilding my T&P layout HO scale
[ Active Members: 0 | Anonymous Members: 0 | Guests: 70 ]  [ Total: 70 ]  [ Newest Member: HolmesELP ]
Author Previous Topic: Avalon Tippi Foam Cutter Topic Next Topic: Laser cut layout modules in North America
txdyna65
Posted - 02/17/2019 :  8:42:05 PM  Show Profile  Reply with Quote
Reposting since my other thread disappeared.
Im rebuilding my HO layout and wanted a place to post pics and progress and get help that I know I'll ask for and need. My building is 30 X 15 and just for my trains. Below is my track plan. My last layout the table were too wide and hard to work on. This time around The widest table is 42" but I have access on all sides. I also wanted a turntable and a yard and be able to run trains, so I made 2 mainlines. If anyone sees problems with my track plan, would love to hear it. Ive only built a few tables so I can still change the track plan somewhat if need be.
Kenny
Country: USA | Posts: 55
txdyna65
Posted - 02/17/2019 :  8:49:01 PM  Show Profile  Reply with Quote
For some reason I couldnt add to that post, so here is what I have done so far. The turntable is a Walthers 110' and the roundhouse is also Walthers. This layout is DCC and I have an NCE Power Cab pro R.
The tables will have 2" foam on them except where the turntable is, I plan on putting thin cork in this area, and regualr midwest cork for mainlines. Most of my curves are 30 deg radius, with a couple being 24 deg. All turnouts are #6 except in the yard, those are peco #5.
Rick created a monster when he helped me post pics.
Kenny
Country: USA | Posts: 55 Go to Top of Page
txdyna65
Posted - 02/19/2019 :  03:22:49 AM  Show Profile  Reply with Quote
I forgot to add my progress picture of my 300 ton coaling tower. Im not sure I like the color of the NBW in the pic, but they look good in person, to me at least.
Kenny
txdyna65
Posted - 02/22/2019 :  01:40:24 AM  Show Profile  Reply with Quote
I got more done to the coaling tower, now for the hard stuff, building the walkways and stairs. I do have a question. The stair treads are made of lead or metal and it calls for adding the wood steps.
What glue would I use for this and does anyone have any tips for keeping these lined up while gluing all those steps on?
I will weather the roof later, just pics of the progress so far.
Kenny
Posted - 02/23/2019 :  4:10:35 PM  Show Profile  Visit jbvb's Homepage  Reply with Quote
I usually glue wood to metal with Walthers Goo. Lead can be tricky with ACC (Crazy Glue etc) because lead oxidizes.
Regarding your track plan, if you wanted it to be easy to operate as two more-or-less parallel railroads, you could replace the two connecting tracks with a crossover at each end of the yard. If both mains will be T&P all the time, this is less important.
Country: USA | Posts: 6513 Go to Top of Page
txdyna65
Posted - 03/10/2019 :  12:36:27 AM  Show Profile  Reply with Quote
I put together a couple of these Tichy kits while I was waiting on glue to dry on another project. I picked up 20 of these for $5 apiece at a train show in colorado last month. I think they will go good with my new coaling tower.
Kenny
txdyna65
Posted - 03/11/2019 :  12:56:02 AM  Show Profile  Reply with Quote
I finally laid some track today. The coaling tower is just set in place. My plan calls for another turnout after the turnout at the bottom of the pic with another track going to the far left of the coaling tower going to the turntable as an outgoing as well. Is this the way it is done? I have another track going to the turntable that will be located to the right and a little up that is incoming to the turntable.
The middle track is to back coal hoppers in and unload in to the pit under the center which I dont have installed yet. Is this all the way it works?
Kenny
Edited by - txdyna65 on 03/11/2019 01:58:44 AM
Posted - 03/11/2019 :  09:41:57 AM  Show Profile  Visit jbvb's Homepage  Reply with Quote
You've got it right about the coaling tower. RRs usually tried to have two tracks to the turntable, one mostly inbound with the ash pit, cleaning rack, etc.
boomer44
Posted - 03/25/2019 :  08:54:26 AM  Show Profile  Reply with Quote
Kenny,
Do you plan on operating from both sides of the peninsula? Will you have a duck under..or.. lift section?
Gordon Spalty
Country: USA | Posts: 236 Go to Top of Page
kyle creel
Posted - 03/26/2019 :  10:17:40 PM  Show Profile  Reply with Quote
Where is/are your depot(s)? Is your era steam, if so where will the water stops be?
Country: USA | Posts: 412 Go to Top of Page
txdyna65
Posted - 03/27/2019 :  12:57:12 AM  Show Profile  Reply with Quote
Gordon, yes I will operate from both sides but mostly in the middle area. I have a lift out section planned at the end of that peninsula. My tables are high enough to duck under but that will get tiresome so I will build another liftout.
Kyle, my era is 1950,1951, so there will be a small mix of diesel (gp7,sw7) and the rest are steam. I have several water towers already built from my last layout and have the stops marked on my paper plan. I just dont show it in the plan I posted here.
Kenny
Posted - 03/27/2019 :  09:17:55 AM  Show Profile  Visit Frank Palmer's Homepage  Reply with Quote
Quite the ambitious project. I don't know how much help you'll need if this is the second go-round.
Country: USA | Posts: 5905 Go to Top of Page
txdyna65
Posted - 03/28/2019 :  12:08:39 AM  Show Profile  Reply with Quote
Thanks Frank, tearing the old one down was no fun, but Im having fun taking my time and rebuilding it the way I want it.
I have the 30' table along the back wall completed and 24' of the backdrop done and got most of the yard laid.
Kenny
txdyna65
Posted - 04/07/2019 :  10:10:02 AM  Show Profile  Reply with Quote
Ive been working on the backdrop more. Watched alot of videos and decided to try this way of painting them. My backdrop is 34" high which seems a little tall but it covers the plywood wall and meets with my cedar ceiling and looks nice I think. My last update showed a different part of the backdrop and since doing this part I think I will go back and paint over those clouds and redo them like in this pic. Thanks for looking.
Kenny
thayer
Posted - 04/10/2019 :  12:49:26 AM  Show Profile  Reply with Quote
Kenny,
This looks like a great project, with plenty to keep you busy for quite a while. the track plan looks to have plenty of opportunity to enjoy trains rolling through open scenery, as well as destinations to drive operations.
With all due respect for your efforts, my immediate reaction to the photo above is that the tree colors are much too vibrant. It looks like you are trying to create rolling hills at some distance, and I believe the colors should be much more muted for such a depiction. To my eye the darker colors along the lowest foreground edge look the best and the bright green is too cartoony. I would try to mute them a bit with some overpainting.
All that said, your effort is infinitely nicer than the backgrounds I've never painted.
Thayer
Edited by - thayer on 04/10/2019 12:51:21 AM
Country: | Posts: 280 Go to Top of Page
Posted - 04/10/2019 :  08:57:29 AM  Show Profile  Visit Michael Hohn's Homepage  Reply with Quote
Kenny,
I like the tall backdrop and generous yard. When you’re running trains you will be surrounded by track and scenery.
Country: USA | Posts: 6502 Go to Top of Page
Page: of 2 Previous Topic: Avalon Tippi Foam Cutter Topic Next Topic: Laser cut layout modules in North America
