Railroad Line Forums - Caterpillar Railroad right-of-way cleaning flatcar
[ Active Members: 6 | Anonymous Members: 0 | Guests: 101 ]  [ Total: 107 ]  [ Newest Member: RexsDad ]
Author Previous Topic: You just lost everything, what scale do you start? Topic Next Topic: building permits
Posted - 05/13/2017 :  4:53:41 PM  Show Profile  Reply with Quote
This is by far, hands down, the ugliest model I have ever produced. It is even almost a shame to show to the public. I've had one in use for years, and asked by a friend to make one up for him. So here goes. It is ugly, yes! But also simple to make, great for getting the job at hand done, and easy to clean after use.
This Libman vent brush with Polymer fibers twisted on a steel wire rod 18" long x 1-1/4" wide will be the main working part for this cleaning tool flatcar, for removal of spider webs and critters living in our Railroad tunnels, across the track between trees, and trackside areas. No one said it had to be pretty, it just has to do a good job, and that it does.
I started with a Libman vent brush pictured below, and an old Tyco culvert pipe load flatcar. The first section of the brush was cut 11 long, then bent back at the middle section of its self with the ends turned in and wired together to form the base of the cleaning brush for the top of the flatcar. This oval section is now (from fibers to fibers) measuring 6-1/2 long x 2-1/2 wide. A Standards Gage for HO scale is 2-1/16 wide, and the brush is made 2-1/2 wide to give a good clean swipe through tunnels, and all spaces within the Standards Gage measurement.
After making second cut of the Libman brush at the handle, you are left with a 7 brush to be used for the top of the base to give the height needed on the cleaning flatcar. Both ends, 1 long of the brush are bent down to form a U shape, and give the height needed for the cleaning flatcar. The U shaped brush is set down in-between the base oval brush, and with thin floral wire, tied at both ends to the base. Then the flatcar is weighted down with weights to help hold down to the track, and the brush cleaner is wired to the flatcar. With the Standards Gage up against the flatcar you can see the brush just extends over the top, and the sides for a good cleaning sweep. This model still needs metal wheel sets and a set of Kadee couplers installed. Once it runs around your track with your maintenance locomotive pushing it along, the cleaning flatcar can be wiped clean or vacuumed. Then hidden from the public until the next cleaning run.
Country: USA | Posts: 17016
Posted - 05/13/2017 :  7:15:43 PM  Show Profile  Reply with Quote
Louis, looks like your really trying to brush us off with this one.
And I bet this neat little cleaning car really bristles while it works.
Great idea! Thanks for sharing it with us.
Country: Canada | Posts: 7501 Go to Top of Page
Posted - 05/13/2017 :  8:07:16 PM  Show Profile  Reply with Quote
Ugly it is, but functional. Thanks for the tip. Louis.
Country: USA | Posts: 14212 Go to Top of Page
Orionvp17
Posted - 05/13/2017 :  8:15:16 PM  Show Profile  Reply with Quote
Looking good, Louis, although I really like the black/brown colors in the first shot....
Thanks for the tip. I feel a trip to the hardware store coming on....
Country: USA | Posts: 5728 Go to Top of Page
Posted - 05/13/2017 :  9:19:43 PM  Show Profile  Reply with Quote
I think you can get those Libman brushes at Menard's just an aisle over from their train stuff.
Stand UP for AMERICA!!
Kentucky Southern Railway
Sunfield Township Michigan
Country: USA | Posts: 9035 Go to Top of Page
Orionvp17
Posted - 05/13/2017 :  9:21:35 PM  Show Profile  Reply with Quote
Hardware store is closer and I don't like what Menard's did with Louis' engine house....
Railrunner130
Posted - 05/14/2017 :  09:15:40 AM  Show Profile  Reply with Quote
(Awkward pause.......)
Even though it's for just spider webs, would it make sense to add additional weight to the car?
And you've got to paint that thing like a real MOW car!
Rutland Railroad
White River Division
"The Peavine"
Country: USA | Posts: 346 Go to Top of Page
Posted - 05/14/2017 :  09:40:04 AM  Show Profile  Reply with Quote
Some extra weight is needed indeed, my first car would lift off the track at some areas where the brush would hit an object or tunnel liner, and cause it to derail. Since the added weight, it stays on the track without ever lifting off.
Country: USA | Posts: 17016 Go to Top of Page
Posted - 05/14/2017 :  09:48:42 AM  Show Profile  Reply with Quote
Thanks Karl, I picked up on that statement right away. Even meant as a joke, as stupid looking as this item is, for as functional as it is, I won't put nothing past Menards.
Pete thanks for your thoughts and comment. Menard's is "Definitely Not" my kind of store.
Posted - 05/14/2017 :  09:54:17 AM  Show Profile  Reply with Quote
Thanks Greg, you never let me down with your wit, you should work for Hallmark Greeting Cards making up sayings.
George, glad to pass this tip along. Even just for tunnel use, we all get that occasional locomotive coming out of a tunnel with webs on it over time.
Posted - 05/14/2017 :  8:47:39 PM  Show Profile  Reply with Quote
My comment solely meant as a touch of irony, as I too don't care for their tactics.
kot2b
Posted - 05/17/2017 :  2:17:04 PM  Show Profile  Reply with Quote
Neat Idea and so simple.
Country: USA | Posts: 172 Go to Top of Page
